Ford Expedition
Ford Expedition
Hey guys,
I was doing a brake job on an Expedition. The front pads were completely worn through the pad material, so IDK if the extra heat made it more difficult, but the fron rotor was completely stuck. I sprayed some penetrating oil on it and whacked it with a 2lb hammer to the point that I bent the rotor and it still wouldn't free. I torched it with a propane torch, still no luck. I asked my neighbor, who is a retired mechanic and service station owner, He told me he used to have to drill the rotor around the hub area until he could crack it off. # drill bits later, that's what we did. Now I need to attack the other side. Any ideas? Anyone know if the rears have the same problem?
Thanks
Thanks
Originally Posted by FASTSIIK,Jul 16 2009, 09:18 AM
oh yeah, get a bigger hammer, i used an 8 lb.
this is seriously a horrible suggestion, I want to make that clear ahead of time, but have you tried lowering the truck down onto the rotor?
I have had to do that when I had no other option.
Basically, you just take the wheel off with the car jacked up and then lower the jack until the weight of the car snaps the rotor off. The weight of the vehicle can put so much more force on the rotor than you can with a hammer, and it is continuous.
I have no idea if this would work on a truck. I have done it on a car only. Who knows what kind of potential clearance issues there will be.
