View Poll Results: HP -> Acceleration... not Torque!
HP is more important than Torque
58.62%
Torque is more important than HP
41.38%
Voters: 203. You may not vote on this poll
Old Jun 10, 2003 | 11:23 AM
  #181
Zoran's Avatar
[QUOTE]Originally posted by wc_one
[B]Zoran, you seem to be confusing acceleration and speed, the two are very different.
Old Jun 10, 2003 | 02:21 PM
  #182
wc_one's Avatar
[QUOTE]Originally posted by Zoran
[B]
Good job doing the math, but if you go back to my post you'll see that the
Old Jun 10, 2003 | 03:46 PM
  #183
FCGuy's Avatar
OK, my previous post finally made me realize what is absolutely the simplest way to explain why is it the HP that accelerates your car.
Wheel torque accelerates your car. Everyone (even the most stubborn "torque enthusiasts") will give you that.
Since WheelTorque = EngineTorque*Gearing, and Gearing = EngineRPM/WheelRPM, and EngineHP = EngineTorque * EngineRPM, we get that:
WheelTorque = EngineHP/WheelRPM
At any given speed, there's nothing you can do to change your wheel RPM, so your wheel torque (and thus your acceleration) is DIRECTLY proportional to the engine HP at that RPM.
I really cannot think of a simpler way to explain this.
Bravo! 100% correct, and I hope as clear.
Old Jun 10, 2003 | 04:47 PM
  #184
Zoran's Avatar
What I'm saying is at any given time the max rate of acceleration is at the max torque.
Old Jun 10, 2003 | 04:52 PM
  #185
Destiny2002's Avatar
Old Jun 10, 2003 | 04:54 PM
  #186
wc_one's Avatar
[B]
What does this mean? "At any given time"?
In any given gear, maximum acceleration occurs at the torque peak.
Old Jun 10, 2003 | 05:07 PM
  #187
Old Jun 11, 2003 | 02:35 AM
  #188
Old Jun 11, 2003 | 03:09 AM
  #189
FYRHWK1's Avatar
i've heard that as well, removing 1 lb of rotational weight is like removing 4-5 lbs of sprung mass, then you also have to take into account how much faster the car will be able to rev now that the rotational resistance has lowered and all that goes with that. the 2900 lbs would bebare curb with little gsa in it i'm sure, no driver nor rotational as you said, but that would get tricky adding up the rotational weight unless you know all of the driveshaft, flywheel and prezzurized wheel & tire weights, as well as anything else like halfshafts and so on.
I'd say it proves the same thing really, the actual numbers might be off bu the curves wouldn't change much, you'd still accelerate roughly with your torque curve.
Old Jun 11, 2003 | 06:42 AM
  #190
Zoran's Avatar
[B]
"At any given time" you can only be in one gear (you cannot be in two different gears at the same time) so "maximum acceleration occurs at the torque peak" which is what I mean and we're agreeing on.
