Structural rigidity of cars and stuff
Originally Posted by JonBoy' timestamp='1346687044' post='21984234
I'm still amazed that our S2000s weigh less despite being a convertible, while still having a very stiff chassis.
Cars like the s2000, Miata, Boxster, don't suffer a weight penalty for being convertibles because that's what they were designed for from the get-go. Some of the lightest-weight sports cars of all time have been convertibles: Lotus/Caterham Super 7, Triumph Spitfire, MG Midget/A-H Sprite, etc.
But I don't think the S2000 is lighter than an FD anyway.
My base-model FD weighed 2780 lb. before the LS2 swap, about what an early AP1 or a CR weighs. With the LS2, with P/S, A/C, full interior, roll bar, much bigger wheels/tires/brakes it's at 2830 lb., I believe that's still lighter than an AP2.
Yes, you can make a very light convertible but when dealing with a road car and when you want a given level of torsional stiffness the roof is critical. If you put a structural roof on the Miata it would gain weight and a significant increase in chassis stiffness. If you were to design a similar car using the same suspension and driveline bits as a coupe it should be either just as light but stiffer or just as stiff but lighter. Any way you slice it, for a given level of stiffness a roof makes things better.
The 2 different Corvette chassis might server as an example. The base car has a steel chassis that was designed for a roofless car. This makes sense since all C6s with the steel chassis are either convertibles or targas (ie they don't have a structural roof). The aluminum chassis, while very similar to the steel chassis was designed to take advantage of a structural roof panel. GM knew that without the roof the alloy chassis wasn't as stiff as the steel chassis. By adding the bolt in roof panel frame the net result is a chassis that is stiffer and lighter. Certainly if GM decided to bolt in the roof panel on the steel car they could reduce the stiffness of some of the other parts to more than make up the extra weight even without going to the extreme of the alloy chassis.
In the end, for a given weight a closed box is stronger.
Believe me, I'm a professional structural engineer, I FULLY understand the ramifications of an open roof vs. closed. But in the end, given the design constraints of either open or closed roof road car from the start, and given some reasonable leeway to incorporate stiffnening features in the chassis of the convertible (e.g., S2000 X-bone design), there isn't really much *if any* weight penalty associated with a convertible road car vs. closed coupe. I'll stand by that remark...
Other aspects of the design would likely be impacted, i.e. convertible might have less interior space like you suggested, and/or deeper rocker structures making ingress/egress more difficult.
I have always been a bigger fan of fixed-roof coupes partly for the structural consideration, but having been through multiple (2-wheel) vehicle designs with differing configurations, you just find other solutions for achieving the weight and structural requirements.
A coupe and a convertible of the same size/weight/stiffness will evolve differently structurally, for sure.
Also worth considering that the roof, while being a killer shear panel, is at a huge offset from the firewall and aft structure. To take advantage of the roof, you have to add stiffness (weight) to its perimeter and to the pillars supporting it. It's not as structurally efficient as, say, adding a lid to a shoebox!
Originally Posted by ZDan' timestamp='1346864043' post='21989592
[quote name='rockville' timestamp='1346855278' post='21989138']In the end, for a given weight a closed box is stronger.
[/quote]
true for torsion stresses. car with roof = more of a circular structure = hollow shaft "effect" = more efficient
i call bs on the SE license. pics or it didn't happen
Like I said above, I'm a big fan of fixed-roof coupes, but you can design in required torsional and bending stiffness without a roof at the same weight, with only minor impact to ergos.
Not that any of them is perfect, but still,
