Scott's Camber Tires
I'm also puzzled by these. As aklucsarits pointed out, BFGoodrich built the highly successful Comp T/A R1 tire in the '90s, but its construction was the opposite of the Scott tire -- it had a softer *outer* sidewall, which is logical since it allowed the tire to conform better as the car rolled during cornering. The Scott tire uses a softer inner sidewall combined with lots of static negative camber, which allows for a larger contact patch when driving in a straight line, but would seemingly result in worse response to body roll.
As asrautox pointed out, the non-R-compound Scott tires actually produced worse test results than the OEM tires, which doesn't help the case for the new tires.
The only way I'd actually consider this is if I see some proven numbers under hard acceleration with a comparable tire and some cornering G's along with slalom tests. The design makes sense in my head... but the only part that I'm conflicted with is cornering load.
Originally Posted by tunerjetta29,Apr 30 2010, 08:49 AM
People have been doing this for years when shaving tires for road racing.
TougeMaster
04-08-2016 12:49 AM
