Automotive tools
I posted this on the PPC forums a while back, but it deserved repeating here:-
AIR COMPRESSOR: A machine that takes energy produced in a power station 200 miles away and transforms it into compressed air that travels by hose to a pneumatic impact wrench that grips rusty bolts last tightened 60 years ago by someone in Birmingham, and either breaks or rounds them off.
ANGLE GRINDER: When used to just take off that tiny burr - effectively turns a a perfectly painted panel into a surface resembling that of 30 grade sandpaper. If a wire wheel is attached, can also be used by the more extreme body mutilation afficionados and, for riot control; those sharp little wires shoot off in every direction and, at amazing speed.
BATTERY HYDROMETER: A handy tool for transferring sulphuric acid from a car battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
BOLT AND STUD EXTRACTOR: A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
BRAKE PIPE FLARING TOOL: A device for increasing the diameter of the ends of brake pipes, which is so stupid, that it doesn't know that when the pipe fits perfectly, one of the unions has either been left off or put on backwards.
CIRCLIP PLIERS: Used to prise the lids off paint tins. Work better, if you snap off those silly little nibs that fit circlips.
CROWBAR: A tool used to crumple the metal surrounding that tiny clip or bracket you needed to remove in order to replace a 50p part.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
ELECTRIC DRILL: Normally used for spinning Pop rivets in their holes until you die of old age.
GASKET SCRAPER: Theoretically useful as a tool for stirring tea or spreading mayonnaise, however, used mainly for getting dog-crap off your boot.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate expensive parts not far from the object we are trying to hit. Also used for bending nails. If used properly, nail will bend, then fire itself across the room, as it is now useless anyway.
HOSE CUTTER: A tool used to cut hoses 1 inch too short.
HYDRAULIC JACK: Used for lowering a car to the ground after you have restored your brakes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG 4x2: Used for levering a car upward off a hydraulic jack.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbour to see if he has another hydraulic jack.
LEAD LIGHT: The mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 60-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
MOLE GRIPS: Used to round off bolt heads and to transfer intense welding heat to the palm of your hand.
OXY-ACETELENE TORCH: Used almost entirely for igniting various flammable objects in your garage. However, is also capable of causing the prone user to get out from underneath a car at the speed of light, when the white hot blob of braze won't take on the exhaust silencer, you were hoping might last another week or two, and eventually falls on your chest.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style tin oil cans and splash oil on your shirt; can also be used, as the name implies, to round out Phillips screw heads.
PLIERS: Used to round off bolt heads.
SCREWDRIVER: Device used for opening beer cans. Also serves as a chisel. Primarily used for removing excess skin from palm and making random gouges in things.
STANLEY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on boxes containing custom made leather goods.
SU ADJUSTING SPANNER: Teeny 1 1/2" long mini-spanner; drop into the inaccessible recesses of your engine-bay, to simulate that vintage intermittent rattling noise. If you don't want that vintage sound, it can easily be retrieved, see under two-ton hydraulic engine hoist.
TIMING LIGHT: A stroboscopic instrument for illuminating grease build-up.
TIN SNIPS: See hacksaw.
TWO-TON HYDRAULIC ENGINE HOIST: A handy tool for testing the tensile strength of earth-straps and other lines you may have forgotten to disconnect.
16-INCH SCREWDRIVER: A large engine-mount prying tool that inexplicably has an accurately machined screwdriver tip on one end and no handle on the other.
WHITWORTH SPANNERS: Once used for working on older cars and motorcycles, they are now used mainly for impersonating that 9/16 or any other you've been searching for the last 15 minutes.
WIRE WHEEL: Cleans rust off old bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar callouses in about the time it takes you to say, "Ouc...." See also angle grinder.
Originally Posted by Boab01,Feb 11 2008, 12:33 AM
lol nice one Jo, I should also get a little flexible torch as well
.i've got a streamlight septor, 36hr battery life, 1,3 or 7 leds on at once
other things... heavy bench for bashing stuff on with a huge vice, idealy with an insulated metal oversheet for use when welding
roxy
oxy in a rucksack
Big ball joint cracker if you go near the suspension. I've had ufn & games with the S2000 wishbones in the past - most ball joint breakers are not big enough to fit on certain of the wishbone ball joints - I had to borrow the OEM ball joint breaker from the local dealership.
i think with the problems S's have with suspension bushes, then the 10tonne press would be most valuable
then again having to get seized things apart on the driveway isnt something i look forward to at all.
Originally Posted by euan,Feb 9 2008, 08:31 PM
I generally wait until I know exactly what I need and build up tools gradually rather than buying expensive sets of things at the outset - I've made the mistake before of buying shiny tools that I have never ended up using.
JIT
Machine Mart is good for buying all sorts of things at pretty reasonable prices though IME - good shop in Edinburgh.
JIT
I've also bought a good bit of equipment from Machine Mart and it's lasted very well.
3 car restorations in total and it's all still going strong. The only things that were poor were the various welding clamps that I bought.
I originally thought the Clarke stuff might be poor, but it's been pretty trusty stuff.
Gernby
19
Dec 2, 2004 03:53 PM
This is why I take my car to the dealer to hav everything done - worth every penny
