Engine flush - Honda Jazz
Old Jul 21, 2014 | 01:25 AM
LTB's Avatar
LTB
Default Engine flush - Honda Jazz
Our Jazz is in for its service in a few days and one of the things they mentioned when we booked it in was an engine flush.
The car is on a 59 plate and has only done 40K miles.
A bit of reading on the internet reveals all kinds of stories, mostly negative, but pertaining to older engines.
So is this the main dealers' latest wheeze to extract money from punters or is it a good thing to have done ?
Old Jul 21, 2014 | 01:30 AM
BenRNBP's Avatar
I would take that to mean a coolant change rather than some kind of special thin flushing oil to "clean" the internals - which you are correct in thinking is generally not a good thing to do.
Old Jul 21, 2014 | 01:40 AM
LTB's Avatar
LTB
When I asked what it was for they said it was to help emissions so I'm assuming it is some kind of engine oil chemical flush.
Old Jul 21, 2014 | 01:47 AM
BenRNBP's Avatar
In that case, I'd be inclined to say "no thank you" - as long as it's been serviced every year you shouldn't have and kind of sludge build up. I do tend to run a full fuel tank of Redline SI-1 fuel system cleaner before a service but make sure I've used that tank fully before it goes in to not break down the new oil in any way.
Old Jul 21, 2014 | 02:20 AM
Nick Graves's Avatar
Yes, sounds like Homeopathy to me.
If it's cruddy in there, halve the oil change intervals. But that's usually worn FRM-bore engines that get a lot of VTEC.
Problem seems to be that flushing oil loosens up crud & it can jam up VTEC gauze filters, etc and cause tope-end issues.
Thus, never flush a Honda engine.
Old Jul 21, 2014 | 03:07 AM
LTB's Avatar
LTB
The car is used mainly around town and for commuting so gets very little vtec action.
I had advised the missus that I thought it was a bad idea, but that backs it up.
Thanks.
Old Jul 21, 2014 | 05:04 AM
unclefester's Avatar
Get them to check the gearbox bearings whilst it's in - TSB for them and it's a common fail point.
Old Jul 21, 2014 | 09:03 AM
LTB's Avatar
LTB
Didn't know about that so will ask them to have a look especially as it's still under warranty.
Old Jul 21, 2014 | 11:56 AM
01 to 08 by the looks of it - yours may be outside the affected batch but it's always worth running the VIN just to be sure.
nnnc3v
Apr 18, 2018 10:34 AM
AZS2KDancer
Jun 17, 2012 09:35 AM
magician
Jan 11, 2009 05:13 PM
lower
Jan 14, 2005 02:50 AM
Big Cat
Jul 31, 2004 11:08 AM
