Help with my Ford Focus
Old Jul 27, 2009 | 02:57 AM
mtrueman's Avatar
Default Help with my Ford Focus
Hi there you knowledgeable lot....
My 2003 Ford Focus started playing up yesterday. Under idle its shaking around like a jelly baby doing cold turkey. There is a severe lack of power under load and it drives like a tractor, vibrating considerably. There is also the odd backfire and a bit of a pong coming from the exhaust. To me it seems like a misfire, and based on internet reports im suspecting the coil pack needs replacing.
Ive read that this is a common fault, but wondered if anyone else has experience of this or knows of any gotchas. Also, should i replace the plugs and leads at the same time? Ive read that problems in this area can spread to the leads and plugs and then re-short out the new coil pack if you dont change the whole lot.
Ta muchly
Mark
Old Jul 27, 2009 | 03:32 AM
soulcrew's Avatar
sounds like the coil pack to me.
mine went like that felt like it was running on 2 cylinders.
very easy to replace.
Old Jul 27, 2009 | 04:18 AM
AlyWW's Avatar
My wifes 2002 Focus did the same thing - although the engine management light cam on also. I called the AA as I was away from home at the time - the AA man said it was so common he kept a coil pack in stock in his van. 5 minutes to fit and all sorted.
Old Jul 27, 2009 | 04:26 AM
mtrueman's Avatar
cheers people. I'll get hold of a coil pack asap.
Old Jul 27, 2009 | 05:06 AM
Nottm_S2's Avatar
pull the leads off and one wont make a difference, that's the dodgy one
mattg4321
Car Talk - Non S2000
Sep 22, 2015 08:44 AM
iloveyourhonda
Nov 21, 2014 09:07 PM
BrandonJay_1983
May 4, 2007 08:46 AM
blkatz1
Nov 17, 2006 09:11 AM
supwithyou
Mar 9, 2003 09:10 PM
