2001 ECU Swap
Old Mar 12, 2013 | 07:56 AM
elksman's Avatar
Default 2001 ECU Swap
I Wanted to find out if anyone in the Raleigh/Durham area has had their AP1 ecu swapped at one of the local dealers. If so, what was the cost? I changing my 2001 ecu with a 2003. I know that the keys have to be reprogrammed for the ecu and the VIN for the new ecu is needed.
Does anybody work at one of the dealers and knows how to do this?
Thanks!
Old Mar 12, 2013 | 08:17 AM
starrman's Avatar
Not sure if anything has to be done...the 03 ecu does not throw the vin when being inspected...that did not start until 2004. Not sure about keys...but would think it should just plug and play...have you tried it yet?
Old Mar 12, 2013 | 01:51 PM
dc2-2-ap1's Avatar
^ I believe the dealership needs the vin to properly program the key.
Old Mar 12, 2013 | 04:30 PM
Pinky's Avatar
I did it with my car. '00 with an '02 ECU. Dealer charged I think $65 to program it. You need their computer system hookup to do it. They did not need the VIN of the old car far as I know.
Any dealer should be able to do it but I would probably just prep it and unbolt the ECU to make it super easy for them......less things to go wrong as I am sure you will take greater car than them in taking things off/putting them on.
Old Mar 12, 2013 | 06:05 PM
thielepr's Avatar
It's not plug and play. You would need to reprogram the new ECU to accept your keys. Your nearest Honda dealer will do it for for you. You can also swap the immobilizer or whatever is the name from your old ecu to the new one if you know something about electronics
Old Mar 13, 2013 | 06:18 PM
SgtB's Avatar
An 01 imob board will not swap into an 03 ecu. You have to get the 03 programmed like stated above.
Old Mar 14, 2013 | 06:35 AM
Ultimate_Combination's Avatar
Around 3 years ago, I swapped my '01 ecu to the '03 ecu. Did this at the Southpoint Honda in Durham. Drove inside and to the side of the Service Area, got on the ground and swapped the ECU's around. Had a service guy come over with his nice lil Honda diag machine and reprogram the 2 keys. They will need the old VIN of course. Whole process took under an hour and cost me about $65.00
That's the best way to do it.
Old Mar 14, 2013 | 07:28 AM
elksman's Avatar
Yea, maybe I'll contact them instead.
I just talked to Leith Honda in Raleigh and they wanted $55 to program both keys, but they also wanted an extra $110 to swap the ECU which is like a 20 min job at most. I guess I'll just do the swap to the side of their service area.
Old Mar 14, 2013 | 04:09 PM
wadzii's Avatar
Banned
I should be able to swap the immobilizer board from one ecu to the other. I'd have to pop the cover off the ecu to see for sure, if so it takes about 20 mins.. pretty simple to do.
Old Mar 17, 2013 | 07:43 AM
SgtB's Avatar
It worked for you? I had a type 1 board in my 01 and a type 2 in my 03. They wouldn't talk. I was under the impression that the codes where stored off of the daughter board and it just ran the encryption.
Gios2k^
Jan 29, 2012 08:31 PM
fin man
Sep 27, 2011 10:09 AM
deathsled
Nov 3, 2009 04:26 PM
Envied
Aug 11, 2007 10:52 PM
spessx
Jan 26, 2006 01:35 PM
