Engine Cleaning
Old Feb 23, 2010 | 05:35 AM
Saki GT's Avatar
Originally Posted by krshultz,Feb 22 2010, 02:46 PM
What is that hole in the firewall plastic?
Old Feb 23, 2010 | 05:36 AM
mlc's Avatar
mlc
I think that is just the vin# blacked out.
Kevin
Old Feb 23, 2010 | 10:10 AM
krshultz's Avatar
Warning, long post!!
Originally Posted by JCoxRocks,Feb 23 2010, 03:40 AM
Man. I'm in need of a Shultz Detailing special on my engine bay. We gotta work something out. I'd be more than happy to trade you my wheels.
J
J, thanks for asking, I'd be delighted to help you with your engine bay in trade for your Volks. I'll even throw in one of my sets of wheels. You can choose from the ratty AP2V1s or the Rotas. You can even keep the Goodyear GS-D3s. When can I come by and make the exchange?
Seriously, I'd be more than happy to help, and now, I wish I'd brought some stuff on Saturday, I'd have done a bunch of them there. It's actually quite easy. Here's what I do; it's a pretty similar process to the ones posted above.
1. Cold engine. Open the hood. Cover the electrical components if you must, but that's largely unnecessary. All you need to do is use some judgement and not spray water directly into them for long periods of time.
2. Rinse the engine bay. Cold, low pressure water, straight from a garden hose is fine. Some people use a power washer, and that's usually okay, it's just not necessary, so I avoid it. Better safe than sorry.
3. Spray down the entire engine bay with an all purpose cleaner (APC) that's safe on this kind of thing. I use a cleaner called "Super Green Stuff" that Majestic Solutions in Raleigh makes. It's wonderful stuff, and cheap too, at $12/gallon. I mix it 4 parts water.
4. Once the engine bay is good and wet with APC, use brushes and sacrificial microfiber towels to clean up the really nasty bits. I say "sacrificial" because if your engine is really nasty, you might not want to reuse these towels on anything but engines, wheels, door jambs, etc. The Costco yellow microfiber towels are great here.
5. Rinse off the all-purpose cleaner with water, just like you did in step 2. As before, no need for super high water pressure.
6. Satisfied that it's clean and sparkly, dry it off, with an electric leaf blower. This works GREAT. Much less tedious than using towels, and often much more thorough.
7. With the engine dry, I liberally spray the Meguiar's Hyperdressing (4:1 water:concentrate) all over everything. Everything.
8. Close the hood. Start the engine and let it run for at least 10 minutes. This gets the dressing to set up, and dries off a lot of the excess. Hyperdressing is water based, so a lot of the excess will simply evaporate with heat.
9. Re-open your hood. With more clean towels, wipe down any remaining excess. You'll probably still find some in low spots, that's okay. By now, the job is pretty much complete. Nice, clean, sparkly looking engine bay, without leaving everything super slick with solvent-based dressings.
I use this process for every engine bay I do. Here's a BMW 323i I did a long time ago, same process:
Before:
After:
Now, for some "extra credit" S2000 techniques. To be done on a clean engine.
1a. You all know those hard lines for the A/C system, right? Like in the picture I posted of my car a few posts above, the silver ones. These lines are made of aluminum, and polish up nicely. Use whatever metal polish you like, the same kind of stuff you'd use on an exhaust tip for example. Mother's is a perfectly fine over the counter metal polish. Other, more esoteric metal polishes like Wenol, Autosol, Simichrome, Flitz, and countless others are good too. Wenol can actually be purchased at the kitchen store Williams-Sonoma, by the polished stainless All-Clad cookware. You can also find great metal polishing products at Harley dealers. After all, who knows how to make metal shiny better than Harley owners?
OK, follow the directions on the polish to polish the metal hard lines. This takes mere minutes and really looks great. The one against the firewall is the only one that's tricky to get to, so be careful, and wear gloves. You can cut yourself on some hidden edges back there. Among the lines that I do are:
- Over by the heat shield attached to the exhaust manifold
- Same side of the car (same line actually), closer to the pass. side headlight
- Another line near the driver side headlight
- The one that runs along the top of the firewall
1b. You can also polish the raised lettering on your spark plug cover. I used a dremel with a cloth polishing wheel and some Wenol metal polish.
Before:
After:
By the way - Wenol is a particularly nice metal polish to use under the hood because it leaves a protective coating behind on the metal. Stuff stays nicer looking for longer when you use this stuff.
2. Cleaning up the painted surfaces. By now, a lot of areas like the shock towers and the shut line where the hood comes down should look pretty good. If there are heavy deposits from water spotting or something, try a clay bar, or a water spot remover, to get rid of them. Just cut a small piece of an old clay bar off and use the clay as normal. That way, if you drop the clay, you're not out the whole bar.
To make them pop a little bit more, use some kind of wax or sealant. No need for anything exotic here, I just use a spray sealant. I prefer sealants to waxes here because they withstand underhood heat a little better than waxes do. The best one I've used is made by Duragloss, called Aquawax. Local Car Quest and NAPA stores stock it. Every detailer should have a bottle of this stuff, seriously. It's wonderful. Anyway, apply this to the underside of the hood where you can, the shock towers, the exhaust heat shield, all the painted surfaces you can get to easily. Other areas aren't worth bothering with. Stuff like frame rails doesn't get shot with clear from the factory, so you're not going to get them to come up shiny anyway.
3. The black plastic by the wipers can really let down the look of a vehicle, and this is easy to fix too. You can use any dressing you like here. Hyperdressing works, but since it's water based, it's a bit less durable. I prefer a solvent-based dressing here, something like Stoner's Trim Shine, or Meguiar's Trim Detailer, both can be bought at auto parts stores. Specialty products like Black Wow (available at places like Detailer's Domain and Autogeek) are even better and even longer lasting. Make sure and follow the directions, and wipe up any excess when you're done. Excess dressing attracts dust and looks ratty.
There you go, a "brain dump" on how I do engines. J, let me know when's good for me to come by and steal, er, I mean, admire, your Volks.
(Edit - a poster in W&W correctly pointed out to me that I'd forgotten a rinse step. Added step 5, reordered the rest)
Old Feb 23, 2010 | 10:12 AM
Saki GT's Avatar
Karl you should post that in the wash and wax forum. The only DIY engine detailing thread stickied now is not that great imo.
Old Feb 23, 2010 | 11:06 AM
ljsimp's Avatar
Awesome post very detailed. I will be favorites for sure. It would have been awesome to see this on Saturday. We may need to meet sometime and dress up our hoods. We bring products you coach?
Old Feb 23, 2010 | 11:57 AM
krshultz's Avatar
Absolutely! Although, depending on what people bring, I might try and talk some of you into abandoning certain products in favor of others. I should have brought my supplies with me on Saturday; I had some detailing stuff, but none of it was engine bay related, because I just didn't think to bring that stuff. Next time we're at a meet with a water supply, I'd be happy to help you guys.
zippity
Apr 13, 2014 08:53 AM
g.guess88
Jan 18, 2013 09:28 AM
s2000maniac
Aug 5, 2011 05:32 AM
