Found a tiny hole in my top
Old Mar 24, 2011 | 08:28 AM
  #31
RedCelica's Avatar
i can see sunlight coming through though Def. like to get it handled now before it gets worse.
Old Apr 11, 2011 | 08:57 AM
  #32
RedCelica's Avatar
So I called Leith today and spoke with their SM, Chuck Prier. Apparently Honda is willing to cover half of the repairs at warranty cost...whatever that means. Still have yet to hear back a number. Might just be slapping a patch on it at this rate.
Old Apr 11, 2011 | 02:47 PM
  #33
RedCelica's Avatar
for the time being, this works great and is almost an exact match to the fabric...let's just hope it holds:
http://www.shurtape.com/Default.aspx...&ProductID=111
Old Apr 11, 2011 | 05:40 PM
  #34
SgtB's Avatar
I really recommend the jbweld trick. I've used it on the canvas tops of 2-1/2 ton military trucks quite a bit. if you mix in some black RIT dye it will match perfect. Just barely do the outside if you do it at all. Inside is where you seal and fortify the hole so it doesn't grow. It will outlast the top.
Old Apr 11, 2011 | 08:44 PM
  #35
stradleboy's Avatar
got my top replaced. worst thing is not being able to put the top down in this beautiful weather.
Old Apr 12, 2011 | 04:09 AM
  #36
RedCelica's Avatar
You got yours covered under standard warranty though, right?
Old May 21, 2011 | 06:37 PM
  #37
RedCelica's Avatar
Thanks to Steve (scramblerman) for allowing me to inspect his top! As a result I found out that the elastic straps are worn out that pull the bar back and that's why the bar was causing the damage. Maybe a trip back up to Leith is in order...
https://www.s2ki.com/s2000/topic/870...nv-top-straps/
nm, new straps are $20
http://www.modifry.com/products/ctf/details.htm
Old May 25, 2011 | 04:27 PM
  #38
RedCelica's Avatar
straps installed! Works great!
straighten a few on the kinks out, but man they are tight
Old May 25, 2011 | 06:18 PM
  #39
detonator2x's Avatar
Just going to plug this here but Toyo has my old top so if you want a patch of the OEM top, shoot him a PM.
Old May 26, 2011 | 04:31 AM
  #40
RedCelica's Avatar
^^^good to know! Thanks dude
