soft top speed sensor bypass
Old Jul 25, 2003 | 01:51 PM
w1ngman's Avatar
Okay...I officially quit ...
Not to create confusion, but my initial box was meant to represent the same wiring harness that exists under the dash / behind the removable dash panel. It is *there* that I snip the white/black wire...and it is *there* that I came in contact with Reignman's spliced DJ Cube speed variable sensitivity wire spliced into the white/black wire that continued into the wiring harness.
I feel as though I should remove my post/image for fear it will only confuse others......
- Dave
Old Jul 25, 2003 | 03:14 PM
MyBad's Avatar
Oh GAWWWDDDDDDD!
And I let YOU clear my headlights?!!!
Old Jul 25, 2003 | 03:34 PM
airgate's Avatar
OMG! Don't do THIS!
w1ngman did this for me and I thought all was fine, but now the top won't close. Only goes half way. I have my S2000 in service right now because the interior is soaked. My Alpine is ruined.
Juuuuuuuuuuuuuuuuust kidding. I *know* some folks scrolled down just to make sure.
A great mod for sure, I just LOVE it!
Old Jul 25, 2003 | 03:38 PM
SC_Highlander's Avatar
Ok... I went out and took a picture of my rat's nest of wires behind that dash panel. The blue wire is my splice over to the DCI. The black and white wire, I removed from the harness to the top module, as noted by the large circle -- it's the whole pin from the connector that I just taped up.
Old Jul 25, 2003 | 06:28 PM
w1ngman's Avatar
Originally posted by MyBad
Oh GAWWWDDDDDDD!
Scary ain't it!
Seriously...headlight conversions require no more electricity than an electric oven offers
Old Jul 25, 2003 | 06:30 PM
w1ngman's Avatar
[QUOTE]Originally posted by airgate
[B]
[b][SIZE=5]OMG!
Old Jul 26, 2003 | 04:03 AM
MyBad's Avatar
[QUOTE]Originally posted by SC_Highlander
[B]Ok... I went out and took a picture of my rat's nest of wires behind that dash panel.
Old Jul 26, 2003 | 04:11 AM
airgate's Avatar
Originally posted by w1ngman
Raul...this smiley is juuuuuuuust for you, my friend ==>
That is simply classic. Thanks for the laugh and clap seisure.
Old Jul 28, 2003 | 05:24 AM
I think you're saying you totally removed the pin from the harness and left it removed. Is that right?
The harness looks like it has a connector (pin) in it.
That is correct. If I were to unwrap the electrical tape in the big yellow circle, it would reveal the pin that plugs into the "empty connector location".
Old Aug 9, 2003 | 04:15 AM
Luft46's Avatar
I'm no electronics expert either, but wouldn't it be possible to cut the wire and add a small toggle switch in-line? That way you could just flip a switch to bring it back to stock?
