soft top speed sensor bypass
Old Dec 7, 2005 | 11:00 AM
  #61
GranPrix's Avatar
can any1 explain what the DCI is?
Old Dec 7, 2005 | 11:04 AM
  #62
GranPrix's Avatar
ok nevermind, that's if u have Modifry's DCI
Old Jan 30, 2006 | 01:05 PM
  #63
s4play's Avatar
Yo fellas,
I just stumbled onto this super informative thread so much thanks!
a few things:
1) Modifry's site link does not work? Anyone have his new site?
2) What is a DCI and what does it do?
3) I'm very capable on doing the wiring mods/bypass but I noticed for those 2 wire taps (VSS and the E-brake), there are conflicting picture labels for the E-brake, which one is the correct one so I can reference that one?
I plan on disabling the VSS only so no one will try to open the top accidently....
thanks,
rick
Old Jan 30, 2006 | 01:57 PM
  #64
SC_Highlander's Avatar
No problem!
1) Modifry's new site is http://www.modifry.com
2) Modifry's DCI is a Dash Control Interface that allows the stock dash controls to interface to an aftermarket stereo headunit.
3) The first post in the thread has the correct pics.
Old Feb 5, 2006 | 12:20 AM
  #65
spyhunter's Avatar
Originally Posted by Haulin' S,Oct 11 2005, 10:07 PM
Spyhunter,
Did you ever get clarification for me as to which wire it is that needs to be grounded?
The green/white wire gets cut, after cutting it, the part that goes into the controller gets grounded, the part that goes back into the car is left hanging/insulated...
SH
Old Mar 11, 2006 | 04:13 AM
  #66
Gvr4-330's Avatar
Do you think it's possible to add a resistor in-line with the VSS that would change the signal so that you can use the top from let's say 0-10mph, but nothing above?
Rob
Old Mar 11, 2006 | 11:26 AM
  #67
Haulin' S's Avatar
SH
Thank you, sir!
Old Apr 15, 2006 | 12:41 PM
  #68
S2KNJ's Avatar
Hey, y'all
I tried this mod today and found that on my 03 car there wasn't anything that looked like that cover on my passanger side. Just what appeared to be a fan motor and a protective cover with large vent line throuh the floor. the cover had no clips and i couldn't see how to get it off.
I did find the moduals in the picture on the driver's side by the fuses... what gives? are these the same?
THANKS
Old May 11, 2006 | 05:42 PM
  #69
bgoetting's Avatar
S2KNJ
The panel is the piece that the passenger's knee would hit if the seat weren't far enough back. So far I've not been able to get it off or even loosen it. I'm afraid I'll break it if I pull harder.
Old May 11, 2006 | 06:33 PM
  #70
MyBad's Avatar
Is this what you think you'll have to replace?
Panel replacement linky
