Tear in top
Old May 1, 2008 | 09:32 AM
Saki GT's Avatar
Smile Tear in top
So, my warranty runs out this month, and I figured I'd go over the car and fix anything I could find while I'm still covered, and I found two tears in my top.
The fabric is completely ripped, with just the outer vinyl holding. Going in Monday to see if I can get it replaced under warranty.
Old May 1, 2008 | 09:39 AM
airgate's Avatar
I'm always amazed when people say they are going to get this sorta thing covered by their warranty.
Warranty covers something that has defect in workmanship.
The top is a "wearable" item...so how is that covered under any warranty??
My top was replaced at 30k miles because it was truly defective and had a tab portion that would not fold correctly causing it to leave a bulge whenever you put the top UP.
Anyways...I wonder why we haven't come up with a way to sorta "patch" these wear spots from within the top...sorta like those elbow patches...stop it before it ever becomes a problem.
Old May 1, 2008 | 10:36 AM
Rogazilla's Avatar
I bought my car in 04 and the strap was loose causes the folding arm to poke through the top in a month owning the car... Warrenty replaced it... luckily...
Old May 1, 2008 | 11:23 AM
Saki GT's Avatar
Maybe you can explain what isn't a wearable item thats covered under warranty? Doesn't everything wear out over time? Warranties are for replacing things that wear out or break prematurely. A top that gets a rip in it due to defective design qualifies, which is why so many people get their tops replaced under warranties.
Old May 1, 2008 | 12:53 PM
MULDER's Avatar
Good luck Matt.
Old May 1, 2008 | 06:45 PM
whitemistress2k's Avatar
Sux bro Good luck with this one
Old May 1, 2008 | 07:39 PM
Yflyer's Avatar
Gotta disagree, Raul.
This issue with the top is so frequent that it has to qualify as a design defect. Mine showed a rip on the inside after only 8 months. Nothing wrong with the top material -- and it wasn't wear in that short of time, either. That;s something just plain wrong -- defective. Hendrick (Easley, SC) replaced it under warranty.
If Honda doesn't want to pay a lot of warranty claims, they should issue a TSB to fix the cause.
Old May 1, 2008 | 07:47 PM
airgate's Avatar
Yeah...but a TSB would cost $$$ (you know that already)...so they figure they'll just handle them as they come in. Sucks.
Old May 1, 2008 | 07:48 PM
airgate's Avatar
Hey Saki, sorry man...re-reading my post...I came across a little harsh and of course, didn't mean to. I agree with you that it's a design issue.
And on a serious note, why hasn't Honda simply developed something like those elbow patches to go on the inside of the top to prevent the issue??
Old May 2, 2008 | 02:52 AM
Yflyer's Avatar
but then that would cost $$$ Seriously, it seems like a fix like you suggest would cost a lot less than all the top replacements.
Saki, hope they replace your top without a lot of hassles
