Tech Day in Wilmington
Old Oct 25, 2005 | 11:21 AM
S2000driver77's Avatar
Unless something comes up with work I'll probably be by. Valve tapping is driving me nuts.
Old Oct 25, 2005 | 11:39 AM
MyBad's Avatar
Originally Posted by Intense,Oct 25 2005, 02:47 PM
I read somewhere before, but I forgot......how soon/often should one adjust their valves.
Mike,
Valves shouldn't need adjusting until 30k miles or more. However, Some owners have needed adjustments prior to 30k. We'll take a look (listen) at your car and make the call then.
If it ain't broke, don't adjust it.
Old Oct 27, 2005 | 09:21 AM
VFROOOM's Avatar
Originally Posted by MyBad,Oct 24 2005, 04:15 PM
Great! Are you gonna adjust your valves or watch? You really don't need any parts to do the adjustment. Replacing the valve cover gasket is optional.
I should be doing the Valve Adjustment......I'm hoping the parts will be in today.
Old Oct 27, 2005 | 02:20 PM
MyBad's Avatar
Great! I think we'll do YOUR car first.
BTW, don't forget that the engine needs to be cool to do the valve adjustment. You're welcome to bring it over and leave it the night before.
Old Oct 28, 2005 | 03:25 PM
Everything looks good for a nice road trip tomorrow. I'll try to make it 9-10amish.
Old Oct 28, 2005 | 06:04 PM
MyBad's Avatar
Great! Look forward to seeing you.
Old Oct 29, 2005 | 05:42 AM
RWD_HNDA's Avatar
Anyone wanna come pick up my car and adjust my valves for me??
Old Oct 29, 2005 | 01:55 PM
RWD_HNDA's Avatar
So how did everything go?
Old Oct 29, 2005 | 05:16 PM
MyBad's Avatar
We started at 9:00 sharp on my car. VFROOOOM and HOTRODS2000 were on hand to help. Things went a little slow at first as we disassembled things from the valve cover and learned the short cuts to getting the valve cover off. We found that ALL of my valves were out of spec. Too tight!
We had to adjust every stinking one of those suckers and the adjustment process proved to be somewhat tedious. We found that closing the gap with the next size larger feeler gauge, tightening the nut and then torquing it put the opening at the desired clearance...most of the time. You really have to develop a "feel" for doing the adjustment.
After adjusting all of the exhaust valves, the pizza dudette showed up and we took a much deserved break. Leaning over the engine bay for hours takes a toll on the lower back and the backs of your legs. After feasting on the Domino's Extravaganza we tackled the intake valves.
Four hours after starting we finally had my baby back together with NO left over parts and fired her up. Fortunately no piston rods or valves came flying up through the hood. She ran like a top!
Then we tackled VFROOOOM's car. Having gone up the learning curve on my car and only having to adjust 8 or so valves made this a two hour job.
I really wish you guys could have been here. This was a TREMENDOUS learning experience.
A special THANK YOU to Rod and Richard for making this a super day.
Old Oct 30, 2005 | 03:56 AM
rajun asian's Avatar
sounds like alot was accomplished . Wish you were a little closer to me or vise versa .
