Delaware Valley S2000 Members Delaware, Eastern PA (Philly)Southern New Jersey
removing cat
Old Sep 12, 2005 | 03:28 PM
jshimer23's Avatar
Default removing cat
I'm having a bit of trouble removing the 3 bolts on the downstream side of the cat. I'm putting in a test pipe and these 3 bolts are giving me trouble. I don't have air tools so all i have to work with is a basic ratchet and wrench set. I just soaked them with some PB Blaster and figured i'd let work it's way in for awhile. Any tips or tricks to help get the bolts off???
Old Sep 12, 2005 | 06:44 PM
freq's Avatar
That is a great start.
I ended up snapping one of those bolts by hand and believe me I am NO giant. If you don't strip them they will snap. Do you have a Roto-Zip or any way to cut the bolts is all else fails?
Old Sep 12, 2005 | 07:11 PM
jshimer23's Avatar
i have a dremel if need be. i'll find a way to get them off.
Old Sep 13, 2005 | 05:08 AM
phillys2k's Avatar
thats the last thing u want to do put pv blaster on it and wait 1 day let it soak up and spray it again b4 ur about ti put it on.
Old Sep 13, 2005 | 05:27 PM
Clayman's Avatar
It helps if you can get access to some air tools (I know, I know). When I was changing the headers/exhaust on my car, I think I snapped one or two of the bolts. It's not a really big deal because you can just pound them out and put new RUSTPROOF ones in their place. Heave like a mutha to see if you can snap 'em loose, if not, just cut them and replace them (Home Depot is great for that kinda thing).
Old Sep 13, 2005 | 05:40 PM
trich1687's Avatar
I have dealt with these also and they are a pain, I cracked a snap-on socket on one of them. What you need is a 6 point socket NOT a 12 point. then be sure you have the box end of a wrench on the BOLT head, put the socket on the nut with a cheater bar ( a 12" long pipe over the end) of the rachet. One smooth pull don't wimp out it will give. It may snap if so just replace it with A GRADE 5 fastener.
Old Sep 14, 2005 | 08:01 AM
VR WHAT's Avatar
.........believe me I am NO giant.
I can second that notion
Just kidding Joe
Old Sep 14, 2005 | 08:14 AM
freq's Avatar
Just kidding Joe
DAMN.
InVTEC
Jan 8, 2013 07:44 PM
Jacksparrow
Nov 1, 2009 08:09 PM
H-twnBerlina
Nov 10, 2006 07:40 AM
frofro24
Aug 27, 2006 01:29 PM
pjkwong
Jan 24, 2006 03:57 PM
