Delaware Valley S2000 Members Delaware, Eastern PA (Philly)Southern New Jersey
Something doesn't seem right....
Old Oct 16, 2006 | 01:04 PM
slanguage's Avatar
Default Something doesn't seem right....
I have an issue with my S, so I posted it in the UTH forum. Hers the link:
https://www.s2ki.com/forums/index.ph...&f=22&t=430904
Let me know what you think
Old Oct 16, 2006 | 03:48 PM
trich1687's Avatar
My bet would be Axel nut torque also, Bearing would squeal more frequently. Brake caliper hanging up is also a possibility. Fluid is not the answer.
Old Oct 17, 2006 | 04:46 AM
AssassinJN's Avatar
Try retorqueing to the new specification. Do a search on axle nut to find it (probably stickied in UTH as well).
Old Oct 17, 2006 | 02:02 PM
tinkfist's Avatar
36mm, 220 ft-lbs
Old Oct 18, 2006 | 04:38 AM
AssassinJN's Avatar
Or just ask him
Old Oct 19, 2006 | 11:33 AM
slanguage's Avatar
updated info in link listed in 1st post
Old Oct 19, 2006 | 11:34 AM
slanguage's Avatar
how do I know if the brake caliper is hanging up? and if so, how do I fix this problem?
Old Oct 20, 2006 | 04:10 PM
trich1687's Avatar
It may be hard to actually feel if it's hanging up because it could be random or be worst when hot. I would look for uneven pad wear between one side of the car or the other and look for excessive or uneven pad wear inboard verses outboard. Could jack it up and try to free spin the wheel after a spirited run. Soultion is to either rebuild the caliper or at least disassemble and clean/pollish the travel surfaces.
Old Oct 20, 2006 | 04:41 PM
slanguage's Avatar
i checked all the brakes front and rear. no unever wear. brakes are all in good shape
Old Oct 20, 2006 | 05:03 PM
revhi's Avatar
Are you sure its coming from the wheel/brake area and not the suspension? Also check your spare tire to make sure its down tight.
AliGod78
Nov 9, 2015 02:31 AM
miamirice
Oct 6, 2010 06:16 AM
junsu
Feb 29, 2008 08:57 AM
Tedster
Feb 18, 2003 08:33 AM
1FastS2k
Dec 1, 2002 11:29 AM
