help!
I just changed my ap2 clutch to a act street disc clutch kit with a ap1 flywheel ..after I put everything back the pedal is really stiff and won't engage into any gear..did I put the clutch fork wrong maybe???? Any help will be really appreciated
I just left ..but I will post pics. Tomorrow in the morning I doubt i put the disc backwards because if I did wouldn't it make a chattering noise...well that was what happen when I changed it on my old civic ...but could it be also that I'm using a ap2 throw out bearing with the ap1 f.w ? I'm just really lost right now
Again the disk only fits one way. If you have it backwards you would have not been able to put on the pressure plate.
Regarding the fork, make sure the small "divot" is facing the slave pushrod. It clicks into the clip thats in the transmission.
The troughout bearing should be fine, its the same. Did you install the bearing correctly? This is a pull type transmission ... so you would have the clutch disc, then the bearing and then the pressure plate ...
J
J
