help!
Old Jan 14, 2011 | 03:14 PM
BigRed2's Avatar
Default help!
I just changed my ap2 clutch to a act street disc clutch kit with a ap1 flywheel ..after I put everything back the pedal is really stiff and won't engage into any gear..did I put the clutch fork wrong maybe???? Any help will be really appreciated
Old Jan 14, 2011 | 03:16 PM
Harper Racing's Avatar
um... i would probably have toy say the disk is in backwards...
BigRed2's Avatar
I ask about the fork because looking at it..it seems to not have enough leverage to disengage the clutch
Old Jan 14, 2011 | 03:20 PM
i dont know if you can put that in backwards... (someone correct me if im wrong) pix please?
Old Jan 14, 2011 | 03:29 PM
R1_Pilot's Avatar
disk goes in only one way. Your problem is most likely related to the fork.
Remove the two bolts on the slave, and take a peak into the transmission through the fork opening.
J
Old Jan 14, 2011 | 03:30 PM
BigRed2's Avatar
I just left ..but I will post pics. Tomorrow in the morning I doubt i put the disc backwards because if I did wouldn't it make a chattering noise...well that was what happen when I changed it on my old civic ...but could it be also that I'm using a ap2 throw out bearing with the ap1 f.w ? I'm just really lost right now
Old Jan 14, 2011 | 03:32 PM
BigRed2's Avatar
Also is there a specific way to put the fork back in the transmission ?
Old Jan 14, 2011 | 03:35 PM
BigRed2's Avatar
The fork is leaning towards the clutch which is why I said it looks like it has no leverage ..is that the problem?
Old Jan 14, 2011 | 03:36 PM
BigRed2's Avatar
Old Jan 14, 2011 | 03:38 PM
R1_Pilot's Avatar
Again the disk only fits one way. If you have it backwards you would have not been able to put on the pressure plate.
Regarding the fork, make sure the small "divot" is facing the slave pushrod. It clicks into the clip thats in the transmission.
The troughout bearing should be fine, its the same. Did you install the bearing correctly? This is a pull type transmission ... so you would have the clutch disc, then the bearing and then the pressure plate ...
J
