k24 block with k20 head?
Old Oct 10, 2006 | 03:26 PM
beautyofS2K's Avatar
Default k24 block with k20 head?
https://www.s2ki.com/forums/index.ph...&f=22&t=429528
Old Oct 10, 2006 | 04:22 PM
Bandiscoot's Avatar
yes ... very well.
Skunk2 and Realtime racing have both done this for obvious reasons. Still decent rod/stroke ratio. 2004 and up K20 heads (RSX-S) came with JDM intake cam and intake manifold. Only published a 10hp gain with OE programming but that obviously is worth more once 'adjusted'.
Just do a little research on any motor-swap pages for Civics ... including the new Honda Fit!!! Honda-tech would be a good place to look.
Old Oct 10, 2006 | 08:17 PM
2NRWRNCH's Avatar
Nothing like TQ and REVS.
Old Oct 11, 2006 | 05:56 AM
Bandiscoot's Avatar
wow ... yer right ... tough combination to find ... but that does seem to produce a decent amount of both.
Anyone have the linky-link to the Exige with that setup??
Old Oct 11, 2006 | 07:00 AM
zacksdad2's Avatar
Here is what I have but, not sure if it is the one that you are lookng for...........
http://www.prototyperacing.com/k20kit.htm
Scott
Old Oct 11, 2006 | 07:47 AM
Bandiscoot's Avatar
that's one of them ... i thought i had seen one with the k24/k20 combo. I could have just been dreaming.
Not sure if everyone doin these conversions knows ... but, a really good transmission setup would be to use the RSX-S gears and the TSX casing (the casing is a magnesium alloy!). I forget the weight difference ... but it is worth it if that's what you're after.
Garrett_si
Aug 27, 2009 01:28 PM
dundonr
Jan 3, 2003 12:25 PM
