F20C1 head flow #'s
Old Dec 27, 2002 | 12:35 AM
dundonr's Avatar
Default F20C1 head flow #'s
Just did a little research, in comparing the F20C1 head flow/cam lift (only on intake side vs a few domestic V8's)
no wonder it makes so much power for it's size....
all @ lift 28"
F20C1(S2000) max intake lift .460 (had to convert from 10" lift to 28" lift)
87 @ .100
174 @ .200
241 @ .300
288 @ .400
311 @ .500
98 4.6 DOHC (Cobra) max lift on cam intake .394
96 @ .100
167 @ .200
223 @ .300
244 @ .400
248 @ .500
LS1 .472 max lift on 97-99 cam intake in C5
83 @ .100
134 @ .200
189 @ .300
222 @ .400
240 @ .500
5.7 Hemi (couldn't find specs on the cam)
65 @ .100
144 @ .200
214 @ .300
250 @ .400
262 @ .500
Old Dec 27, 2002 | 08:04 AM
brogers's Avatar
Very interesting... Thanks!
Old Dec 27, 2002 | 09:57 AM
ultimate lurker's Avatar
Yes, when we did the flow testing on the F20C we were very impressed (data is at www.alaniztechnologies.com and there is an article at www.vtec.net). Looking at all the data I've been able to find, its arguably the best production cylinder head around. Especially when you begin to look at its valve area and port volume vs. some of the other heads out there. Its even more impressive from that perspective, because, as usual, Honda has done more with less.
UL
Old Dec 27, 2002 | 01:00 PM
Uncle Fester's Avatar
I'm kind of surprised by those numbers as well. But the formula for making power (on gas engines anyways) is by burning more fuel and air. So to get all of that power, Honda engineers knew they needed a design that would flow air very well. The F20C1 is the realization of their vision.
Old Dec 28, 2002 | 01:13 AM
HwangTKD's Avatar
UL,
When do you think that the next article will be out? We are all eager to see if you can drum up some extra HP for those who want to stay NA
Bobby
Old Dec 28, 2002 | 06:13 AM
Actually, a member here was supposed to have his head in the shop over the holidays. We did all the before dyno work, etc. Unfortunately, he had some personal issues that got in the way. At the rate we're going, my warranty is up in March, so maybe I'll just do the headwork myself - but I really wanted someone who wasn't involved with the project to do it as they'd be less biased toward any particular result.
UL
Old Jan 3, 2003 | 12:23 PM
stupidNSX's Avatar
if you want to stay na id suggest raising displacement to 2.3 liters and about 40 more ponies will be there for you to punish your tires with. this is good time for an exhaust, header and new air box. head work is the best though, cams, gears and valves. expensive but the most numbers out of an N/A motor are found here.
Old Jan 3, 2003 | 12:25 PM
stupidNSX's Avatar
Feels makes a good stroker kit that might be better to buy when you are thinking to rebuild, because it comes with a $5000.00 price tag
Honda_Mad
Jun 1, 2019 05:45 PM
Garrett_si
Aug 27, 2009 01:28 PM
F20Cdriver
Socal Swap Meet
Nov 18, 2008 12:49 AM
LlamaS2K
Aug 21, 2008 09:21 PM
fperra
Sep 12, 2004 07:34 PM
