magnetic plugs
Old Mar 6, 2009 | 11:05 AM
DannyCoolBeans's Avatar
Default magnetic plugs
Do you guys prefer the longer drain bolt or shorter one?
http://www.evasivemotorsports.com/Merchant...KICS-DRAIN-PLUG
http://cgi.ebay.com/ebaymotors/Blox-Racing...3QQcmdZViewItem
thx
Old Mar 6, 2009 | 11:46 AM
cosmo rockit's Avatar
Is this one of those trick questions? I've always thought it was how you use it not length. Experts please weigh in.
Old Mar 6, 2009 | 12:47 PM
ComposiMo's Avatar
Nothing wrong with either... i'd personally go for the short one though.... less to go wrong if ANYTHING is going to go wrong with a drain bolt... lol!
One thing to think about though, is that if you have enough metal shavings in your engine to overwhelm the short one like in your first link (which is the one i have btw), then you have WAY bigger issues than whether or not you should have gone for the longer magnet.
Another thing to consider is if you are getting bearing wear, don't worry about it... the bearing material won't stick to the magnet anyhow, unless you get to the steel backing, which... again... won't matter how long or short your magnet is. Any material that is going to be collected by the magnet if you are having bearing wear will likely be actual crank material.
And don't worry about buying one for the trans... it has a very healthy sized magnet in it already courtesy of Honda
Old Mar 6, 2009 | 04:00 PM
thx
Old Mar 6, 2009 | 07:02 PM
PrimoGen's Avatar
But a magnetic oil plug only if you want to over worry yourself everytime you change the oil LOL
S2KERRP2
Jul 13, 2014 04:22 PM
s2000maniac
Nov 7, 2012 06:53 PM
Kenshyn
Jan 17, 2012 11:33 AM
MP2k
Nov 30, 2010 01:14 PM
Smit
Aug 30, 2009 05:14 PM
