Throttle Position Sensor
Old May 20, 2010 | 01:02 PM
Bigmanslim's Avatar
Default Throttle Position Sensor
So the other day I am driving and my Check Engine Light comes on. When I am coming to a stop or at a light, my rpms will decrease drastically, sometimes stalling the engine. I swung by AutoZone to have them run the computer and the code came up for a faulty Throttle Position Sensor (TPS). I'll post the exact code later. None the less, I do some research and Honda wants you to buy the whole new throttle body in order to replace a damn sensor that they riveted on there.
Has anyone had this problem before? I have read that you can use the universal Honda TPS and fabricate a bracket and then adjust the voltage. Does anyone have any experience with this? I'm not about to pay $600 for an entire throttle body when the part I need is only $30.
As of now, I want to get a 12-pack and try to use the step by step instructions I found on some forum and just try to replace the TPS. I'm also looking into junkyards to just get a whole throttle body for cheap.
Any help is appreciated! Thanks!
Old May 20, 2010 | 02:31 PM
Bandiscoot's Avatar
definitely hit the junkyards/classifieds first.
The civic's were the same way for many years (as were most Honda vehicles). There was such a demand created that I believe a company finally did start making just replacement sensors. The hardest part was removing the 'screws' holding the old sensor on. Most folks used a Dremel tool to 'slot' the screws so you could use a 'flat' screwdriver to take them off. I'm just not sure if you can buy just the TPS for the S2000 (or if it's shared with any other vehicle) I may have an RSX throttle body with a TPS out in the garage. Let me know if that will work.
Hope that helps.
Old May 20, 2010 | 02:54 PM
Bigmanslim's Avatar
BTW, the CEL code is P0122.
From what I have been reading, the TPS is univeral for all Hondas/Acuras EXCEPT the S2000 and the '88-'91 Civic/CRX... So I may take you up on that offer and see what I can do.
As far as the dremel, that is what I was told as well and shouldn't be an issue.
Check out these threads: http://www.honda-tech.com/showthread.php?t=2541938 and https://www.s2ki.com/forums/index.php?showtopic=589399
Spitlist
Mar 7, 2007 10:29 PM
6500rpm
Dec 18, 2006 08:26 AM
dika
Feb 27, 2005 11:00 AM
slater98
Feb 10, 2004 10:26 AM
bunjimobile
Jan 24, 2004 10:28 AM
