help
help
for some reason i cant pass emissions i tryed almost everything but i keep having the same code p0411 i have replaced the ecm and put my stock intake on and they checked to see if any lines where wrong and it seemed ok can any one help me i have been dealing with this for a year
Intake has nothing to do with emissions... I'm sure you are failing cause you have a check engine light and as soon as the technician sees it, they fail you on the spot.
P0411 = Secondary Air Injection System Incorrect Flow.
Have you checked all your hoses connected to your intake to make sure it's plugged in correctly? If you can clear the code, you'll pass emissions.
Keith
Keith
Keith
Keith
Just a simple question... Are you running a straight pipe or do you still have your converter?
