Gateway S2000 Owners Members for St. Louis MO and area.
Replacement Battery
Old Oct 2, 2011 | 04:22 PM
Su2uKa's Avatar
Default Replacement Battery
Opinions / recommendations: Honda OEM, AutoCraft Gold, Optima YellowTop, other?
Old Oct 2, 2011 | 09:11 PM
S2K_Shawn's Avatar
I bought in Interstate Megatron 2 a couple years ago. Cost was about $110.
Old Oct 3, 2011 | 03:09 AM
myslows2k's Avatar
I bought an optima a long time ago for my crx. I will be buying another one for the s2k soon
*Edit. After researching the internet for 10 minutes i've found out that duralast gold top is cheaper and better then the optima yellow.
Old Oct 3, 2011 | 08:02 AM
Su2uKa's Avatar
Duralast better generally, or better if you have a sound system? Quick search returned a bunch of threads saying the Gold was better, but mostly if you're looking for extra capacity / reserve due to amps, etc...
Have read that the Optima can be unreliable, but also read that others swear by them. (seem pricey tho')
Thanks for the input - will try Honda first for a price comparison against AutoZone, Advance, etc, and discuss how long the battery should last + see if any warranty is left on mine...
Old Oct 4, 2011 | 04:21 PM
jimmij's Avatar
Mine will be replaced with an optima once it lets go. I am still running on the original battery. Cross my fingers.
Old Oct 4, 2011 | 05:37 PM
Su2uKa's Avatar
Upgraded OEM replacement purchased from Leta for 90 bucks - Honda 100 month warranty - works for me!
Old Oct 6, 2011 | 04:54 AM
FearlessFife's Avatar
I have replaced with the Optima Yellow Top twice now. The main reason I spend the extra money on that one is because I put so few miles on the car, and the Optima batteries are known to hold a charge for a lot longer. I need that long-period of time charge. There are times in the winter where I won't fire up the car for a month. It's a necessary evil for me.
Old Oct 6, 2011 | 04:03 PM
calvinnnnn's Avatar
looking to change my battery soon to a yellow top. i've noticed the dash lights dimming considerably while rolling up/down the windows.
Old Oct 6, 2011 | 05:27 PM
Su2uKa's Avatar
2 yellow tops is a lot of $$$s. Maybe better to spend the extra money on a trickle charger, whatever battery you put in the car... I've left my S for a few months at a time throughout my ownership - the original Honda battery only failed after 5 1/2 yrs, and this one is higher capacity with a better warranty.
Old Oct 7, 2011 | 06:28 AM
JulieU's Avatar
Administrator
That sounds more like a bad alternator than a bad battery. Do your dash lights flicker at idle?
