Help!
My e-brake seems to not work very well. The other day in a drive-thru I put the e-brake on but forgot it was on; the car drove forward to the window with what felt like only a minor grip power in the rear. I was wondering if anyone could help or might know what would cause this?
Thanks,
Timothy
Thanks,
Timothy
A while back, I researched this a little because my e-brake is also weak and I believed the e-brake cable to be loose.
I know one can find DIY for adjusting the cable but I did not run across one on the S. Also, I've read that sometimes adjustments in slack must be made "back to front" or from earlier points in the mechanism? (I know, vague...). Hope someone else can provide a better answer for you Tim since my S knowledge is so limited!
Check out your Service Manual.
