Georgia S2000 Owners For owners from Georgia
Help!
Old Jun 30, 2008 | 06:32 PM
yarbrough's Avatar
Default Help!
My e-brake seems to not work very well. The other day in a drive-thru I put the e-brake on but forgot it was on; the car drove forward to the window with what felt like only a minor grip power in the rear. I was wondering if anyone could help or might know what would cause this?
Thanks,
Timothy
Old Jun 30, 2008 | 06:48 PM
altahina's Avatar
A while back, I researched this a little because my e-brake is also weak and I believed the e-brake cable to be loose.
I know one can find DIY for adjusting the cable but I did not run across one on the S. Also, I've read that sometimes adjustments in slack must be made "back to front" or from earlier points in the mechanism? (I know, vague...). Hope someone else can provide a better answer for you Tim since my S knowledge is so limited!
Old Jun 30, 2008 | 07:05 PM
yarbrough's Avatar
Mine also, that is why I am looking for help!
Old Jul 1, 2008 | 03:51 AM
jphish's Avatar
You may need to pull the ebrake up a little more or adjust the cable. Check out your Service Manual.
Old Jul 2, 2008 | 06:18 AM
dan_uk's Avatar
I don't think they work very well on s2000's
I have to yank mine up nearly vertical if I'm parked on a hill or something
Old Jul 2, 2008 | 08:19 AM
yarbrough's Avatar
Thanks Dan. I was thinking I do not use it that much anyway. I might just need a brake job front and back.
Old Jul 2, 2008 | 08:35 AM
ToEnvy's Avatar
I had to adjust mine on the prelude a few times.. it was fairly easy. I'm not too sure on S... I don't use my parking brake unless im putting the top up/down.
Old Jul 2, 2008 | 06:53 PM
RENDERMAN's Avatar
How are your brake pads? If the cable is not completely loose you may need adjustment. As your brake pads wear out the emergency cable develops more play(lag)
loftust
Dec 17, 2010 02:28 PM
tkdsungjin
Dec 17, 2010 07:37 AM
dtmcnamara
Oct 3, 2009 08:54 PM
gst19psi
South Florida
18
Feb 26, 2007 06:39 AM
PilotChris
Jun 8, 2003 07:16 PM
