Georgia S2000 Owners For owners from Georgia
Temp water gauge (Help)
Old Nov 10, 2008 | 08:08 PM
ATL_S2K's Avatar
Default Temp water gauge (Help)
ok, i was driving last night and all of a sudden the temp gauge went from normal which is a 3 bar to like 5 bar near the H. Im not a car expert but,
im guessing its the coolant is low ,which causes the temperature to rise up to 5-6 bar? is that right ?
Old Nov 11, 2008 | 04:28 AM
jphish's Avatar
Did you recently do something with the coolant? If you didn't bleed the coolant right after a flush, it can cause that as well. If not, check for leaks. Check all your hoses for tears.
Old Nov 11, 2008 | 06:35 AM
dan_uk's Avatar
unless you are using the modifry temperature converter that is realy bad
I've seen a 4 briefly on trackdays, I would not run the car till you find out whats wrong
Old Nov 11, 2008 | 06:55 AM
geoffrey06's Avatar
If it jumped really quickly then something electrical is probably wrong. If it took maybe 20 or 30 seconds to do it then it could have over heated. Did you continue to drive, or did you pull over after this happened?
Old Nov 11, 2008 | 09:18 AM
ATL_S2K's Avatar
i pull over and check itwas night time at the moment, i check under the car and the hood, there wasn't any leak. I pull over at a QT and bought some coolant, i check the coolant fluid and it was low. i fill it up and while driving home for like 15min the car was fine. But then i got home it went up to 4 bar.
Old Nov 11, 2008 | 10:58 AM
ATL_S2K's Avatar
i just ask one of my friend and he said it was the themo stat that needs to be replace.
abroke1
Jun 16, 2013 05:50 PM
Static sean
Mar 4, 2013 11:54 PM
AlX Boi
Dec 29, 2009 08:33 AM
METATRON
Apr 27, 2007 12:28 PM
supersulli
Dec 13, 2004 05:21 PM
