$#()#($* 88th Official Hard at Work Thread #)(&*)(
Old Dec 12, 2006 | 06:42 AM
  #161
GOGOGO's Avatar
Originally Posted by FF2Skip,Dec 12 2006, 10:38 AM
I've also been told that how tightly you strap down a car can make a difference when using roller dynos.
I have been told it matters WHO does the dyno. The same car can read different on the same day, even minutes after the previous dyno. And if you have a different human smashing the throttle different than the first, slighty faster, slightly slower can change the reading.
Old Dec 12, 2006 | 06:43 AM
  #162
GOGOGO's Avatar
And the strapping does matter. Some slippage at peak torque can occur if not tight enough.
Old Dec 12, 2006 | 06:44 AM
  #163
civicguyinva's Avatar
Skip,
The InlinePRO dyno was with the stock 10:1 diaphram
The Mach V dyno was with the 12:1 diaphram.
Richer fuel mix, but still not rich enough.
I was rather disappointed with the results. I was under the impression that since my bearings were bad when it was dyno'd at Inline and I had the whole thing rebuilt, that even with a richer fuel mix I should've been able to retain my 314ish whp.
BUT...now Kevin says they are lower then others so maybe I'm still right on track
Old Dec 12, 2006 | 06:49 AM
  #164
NO S8NT's Avatar
Kevin, do you know if that's a linear difference or is it more of a percentage? I do find it interesting nonetheless. If Church's in Cali reads higher than most others and we're not even close to theirs and Ultimate's is even lower, no one can ever know what they really have. I know they don't mean much for comparison purposes unless comparing cars are dyno'd the same day. I've also been told that how tightly you strap down a car can make a difference when using roller dynos.
Honestly I don't know, but If I were to guess, I would go with percentage.
Old Dec 12, 2006 | 06:53 AM
  #165
FF2Skip's Avatar
Me, too.
Mike, don't sweat it. If anyone wants to know, just whip out the higher dyno sheet. Bench racing sucks anyway... because I always lost.
Heck, most of the time most of my parts are on the bench!
Old Dec 12, 2006 | 06:55 AM
  #166
I'm not worried much about numbers compared to others. I'm more worried about losing power and still being too damn lean. If I was a numbers queen I would've gone turbo. I'm still VERY happy with this setup.
Old Dec 12, 2006 | 07:04 AM
  #167
Hi Kevin. Long time no see/talk.
Old Dec 12, 2006 | 07:05 AM
  #168
FF2Skip's Avatar
I understand and did not mean to imply that you were hung up on the numbers. I do remember more than one of us saying, "Oh, I'll be happy to hit xxx hp." We'd hit that, and then immediately start taking steps to ratchet it up a bit.
You may run a little leaner with the cool, dry air we've been having. I'm sure once we get some moisture in the air or temps warm up, your A/F ratio should fall back in line.
Old Dec 12, 2006 | 07:10 AM
  #169
Old Dec 12, 2006 | 07:17 AM
  #170
C45P312's Avatar
Nice numbers bud, what is the setup again? I just read the signature and didn't tep. didn't even notice we were on a new HAW thread
