#@$%$85th Hard at Work Thread#$@#$
Old Oct 11, 2006 | 07:03 AM
  #911
O-turn's Avatar
Originally Posted by NO S8NT,Oct 11 2006, 10:54 AM
Comptech or Vortech SC?
Vortech
  #912
O-turn's Avatar
Originally Posted by CaptKirk,Oct 11 2006, 10:58 AM
Yea with a pulley change, fuel pump, and injectors that shouldn't be a problem at all. The e-manage should be able to handle that...
What would you reccomend Parts wise?
Old Oct 11, 2006 | 07:13 AM
  #913
NO S8NT's Avatar
Originally Posted by O-turn,Oct 11 2006, 10:03 AM
Vortech
750 injectors
4.5 pulley
3.5 map
2mm headgasket
should put you in the 360-370 range
Old Oct 11, 2006 | 07:15 AM
  #914
CaptKirk's Avatar
as far as pulleys are concerned, youd need to check with someone who has experience with SCs... like Kevin.
Fuel pump: Walbro 255lph is the most commonly used one. Some people have had problems with these but a majority of people still use these. I have one of these. There are other brands out there too if you want to get something different.
injectors: I think stock injectors are 440cc if I'm not mistaken. You will need to upgrade these for safety's sake. I have precision 675cc injectors. I think 675cc injectors would work for you too. They give you a lot of room to play with.
and most important of all, a good tune. When you go with emanage, you need to make sure you go to a tuner that knows what they are doing and can tune your car properly...
Old Oct 11, 2006 | 07:16 AM
  #915
CaptKirk's Avatar
Originally Posted by NO S8NT,Oct 11 2006, 11:13 AM
750 injectors
4.5 pulley
3.5 map
2mm headgasket
He said he doesn't want more than 340 whp...
so I'm not sure what boost he has to run on a SC to get that. He shouldn't need to do a headgasket for that, and he def. wouldn't need the 750cc injectors. and depending on the boost he needs to run, he might not need the upgraded map sensor...
Old Oct 11, 2006 | 07:33 AM
  #916
NO S8NT's Avatar
The 2mm headgasket would be good insurance. The stock map is good for up to about to about 12 psi but that's kinda pushing it. 4.5 pulley would put him into that range.
Old Oct 11, 2006 | 07:42 AM
  #917
PopTarts's Avatar
Originally Posted by CaptKirk,Oct 11 2006, 10:50 AM
oh shit...accidental
haven't seen that in a while
Old Oct 11, 2006 | 07:44 AM
  #918
FF2Skip's Avatar
Hey all.
Stock injectors are not 440's... they're more like 380's.
Old Oct 11, 2006 | 07:46 AM
  #919
NO S8NT's Avatar
Originally Posted by FF2Skip,Oct 11 2006, 10:44 AM
Hey all.
Homer
Old Oct 11, 2006 | 07:47 AM
  #920
CaptKirk's Avatar
Originally Posted by FF2Skip,Oct 11 2006, 11:44 AM
Hey all.
Skip
Thanks for the correction
