Questions About Programming Remote
Old Dec 30, 2003 | 09:43 PM
Grazhoppa's Avatar
Default Questions About Programming Remote
I have a spare Civic remote and wonder if it can be programmed to operate the S. Is it possible and if anyone has instructions?
Old Dec 31, 2003 | 06:54 AM
cdelena's Avatar
I don't know if this works but I copied and saved it:
Storing transmitter codes: The codes of up to three transmitters can be programmed into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps. Make sure the doors, the hood and the trunk are closed.
Turn the ignition switch ON (II).
Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the receiver unit behind the driver's side dash.
Within 1 to 4 sec., turn the ignition switch OFF.
Within 1 to 4 sec., turn the ignition switch ON (II).
Within 4 sec., turn the ignition switch ON (II).
Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again. The keyless receiver unit is now in the program mode. You must push the transmitter lock or unlock button of the first transmitter again to program that remote.
Within 10 sec., aim the transmitters (up to two additional ones) whose codes you want to store at the receiver unit, and press the transmitter lock or unlock buttons.Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
Turn the ignition switch OFF, and pull out the key.
Confirm proper operation of the transmitters with the new code(s).
Old Dec 31, 2003 | 07:39 AM
Squeezer's Avatar
Old Jan 1, 2004 | 03:16 PM
Grazhoppa's Avatar
Not successful so far. I will try again. Mucho gracias fellows.
Old Jan 21, 2004 | 04:13 PM
C7BLE's Avatar
you do the hokey cokey and you turn around.....
Has to be the worst remote programming sequence I've ever seen!
good luck
Old Jan 22, 2004 | 08:11 AM
dhayner's Avatar
I use my CR-V remote for both the CR-V and the S2000. I'm quite sure that if you get the programming steps right (and cdelena's instructions look right), your Civic remote will work.
Old May 3, 2006 | 05:56 PM
m3the01's Avatar
Ive tried this method about 50 times with no luck.
PS i dont have a softtop or hardtop on right now would this make any difference(no sensors on these specifying they need to be closed to work?)
I uplugged the keyless module but still no woky.
Any help appreciated
Old May 3, 2006 | 07:06 PM
Slows2k's Avatar
Depending on what kind of civic the remore is from, It may not be the correct remote for a S2k.
Old May 4, 2006 | 06:36 AM
m3the01's Avatar
I guess this was a bad place to post, im using the original s2k ap2 remotes that came with the car.
Steven
Cayne82
May 4, 2014 08:13 AM
Terry Kwok
Aug 27, 2010 11:22 PM
skiddy1903
Jan 26, 2008 04:57 AM
wanabe
Nov 23, 2006 09:18 AM
B.C.
Jan 25, 2006 09:57 PM
