had idle issue, fixed but...
Old Apr 5, 2007 | 10:37 AM
s2guru's Avatar
Default had idle issue, fixed but...
i had idle idle issues, the problem was the throttle position sensor was not is the right place....
after a couple hours of the car getting fix, i'm getting a CEL
COde: P0411 Secondary Air Injection System Incorrect Flow Detected
what can be?
what need to be replace?
Thank you
Old Apr 5, 2007 | 01:59 PM
blackout's Avatar
Its your secondary air pump that aids in the warming of the cat converter so that it gets to optimum temp faster, hence reducing cold start emissions. It is not a catostrophic problem, it is expensive and they have put a TSB out on it so it is a "Normal problem"
Old Apr 5, 2007 | 02:33 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Don't complicate things. Just check the vac routing, and direction of white check valve(#1). Cures P0411 90% of the time.
Old Apr 5, 2007 | 08:53 PM
Utah S2K's Avatar
You mention you had "idle problems" and as such you were probably reving the engine in some form. This can also set the P0411 code as well. I have seen it on several cars after people installed intakes and sat there reving it up to see how it sounded or impress their friends. I may even know someone very close that did this with their own new AEM .
Utah
Old Apr 5, 2007 | 10:14 PM
blackout's Avatar
hmm i get the Secondary pump code "Incorrect flow" i cannot remember the actually code # right now, but my pump has an obvious hole melted off the housing so half of the flow is going into the atmosphere...
ll1l2l1l2lll
May 19, 2022 06:52 PM
Jacksparrow
Dec 24, 2008 04:18 AM
LubedKoala
Feb 5, 2008 03:17 PM
Ooalloems2koO
Feb 15, 2005 10:55 PM
