AEM EMS users, where did you install the EMS?
Old 04-26-2003, 06:34 AM
Jenner's Avatar
Default AEM EMS users, where did you install the EMS?
I can't fit mine in my stock ECU location. I've got it wired into the car and am having great success tuning my Vortech supercharger with 750cc injectors and other mods, but I can't use the dead pedal or put the kick panel back on because the EMS unit is in the way!
Any location installation tips, hints or suggestions would be great.
Thanks!
Old 04-26-2003, 08:55 AM
Anthonymv's Avatar
i believe cjb made a harness that puts it under the seat.
Old 04-26-2003, 09:48 AM
Jenner's Avatar
I have a source to get a harness made, I just wanted to avoid that if at all possible.
"Plug n Play" doesn't really work, if the connectors fit in the box, but you can't mount the box close enough to the connectors!!!
There is this stupid piece of metal that helps hold the stock ECU in place, if I could just cut that out I could possibly get the AEM EMS to fit in the stock ECU location....
Old 04-29-2003, 09:08 AM
Jenner's Avatar
I ended up installing it under the steering wheel. I was able to get the stock wires to reach after undoing a few connections.
Old 04-29-2003, 09:22 AM
cjb80's Avatar
The harness is a much more elegant solution, I mounted mine and several other cars under the seat. You have to take a metal bar and put one end on the stock ecu's tab, and hit it with a hammer.. that will take care of that problem
Chris
Old 04-29-2003, 09:32 AM
Jenner's Avatar
Thanks for the advice(a little late Chris!) but my under the dash location works perfect. This is the same location the Vortech ecu was located so there were already mounting tabs.
Why spend another $150 on a harness when I don't have to
I sold my 10" harness with my emanage....wish I never heard of the emanage. It is a great tool, but not for 750cc injectors or my application!
Old 05-20-2003, 09:25 PM
RCR S2's Avatar
Anyone have base maps of the vortech?
Old 05-21-2003, 04:31 AM
Jenner's Avatar
No one is going to give you a base map that cost them time and money and/or tuning knowledge for free RCR S2!
You can buy mine from me, or wait till AEM releases one(yeah right).
Old 05-21-2003, 04:49 AM
BryanS2k's Avatar
In a sense it did allow you to "plug" and "play". It never said anything about mounting right?
bryan
andrews6
08-02-2009 07:39 PM
ShMooveS2k
07-08-2007 08:29 AM
Headchef
03-30-2007 07:03 PM
busterpit23
06-05-2005 06:52 AM
Quick Reply: AEM EMS users, where did you install the EMS?
