Updated part: Drivers Window Auto Down
Old Jul 8, 2003 | 04:18 PM
Woodwork's Avatar
Hello All:
I have been putting off posting on this subject till I felt good about the "Newest" New part
The facts are this:
The auto down uses a pulser.
The pulser stops working.
The window regulator manufacturer changed the pulser.
The first new regulator worked for a while then the same situation.
It is an intermittent situation.
It is a heat related situation.
It is not a water situation.
It goes down far enough to not bother the operation of the roof.
The New, new part is here and I like the design.
There are a lot of parts in the warehouses and there are more on the way.
The Service Bulletin 01-008 has been updated online and your dealer will be able to get the new part number.
The cars built after (03 model year): JHMAP114*3T002606 already have the new regulator.
The regulator has been in my 02 car since early February and works fine.
HTH,
Woodwork
Old Jul 8, 2003 | 05:53 PM
dlq04's Avatar
Thanks for the ANSWER and once again thanks for looking out for the S2000 community. It's appreciated.
Old Jul 8, 2003 | 06:04 PM
RazorV3's Avatar
wow thanks a lot woodwork. i have a '03 but my vin number ends with 001765, so i guess i have the older regulator. can i have honda just change it to the new regulator since the older ones are known to crap out.
Chazmo's Avatar
Thanks Woodwork. Do you have to have the problem before you can request the TSB work from your dealer? I'm just not positive how the TSB process works. When the sparkplug TSB finally got issued, it was accompanied with a recall...
Thanks.
Old Jul 8, 2003 | 06:21 PM
Barry in Wyoming's Avatar
Great info, Woodwork. Thanks.
I assume that, "If it isn't broke, don't fix it." Mine car is an early '01 but still works without problems, and my Honda Care warranty has 4 1/2 years to run so I'm not pushed by time. Others with an '00 or '01 might be.
Old Jul 8, 2003 | 06:27 PM
boiler's Avatar
Thanks Woodwork for your very timely information. I tried the "fix" and it doesn't work. I had mine replaced last fall and it just now failed again.
Bob
Old Jul 8, 2003 | 07:24 PM
joe_s2k's Avatar
[QUOTE]Originally posted by Barry WY Silver/Black '01
[B]... and my Honda Care warranty has 4 1/2 years to run so I'm not pushed by time.
Old Jul 8, 2003 | 07:50 PM
FormerH22a4's Avatar
Woodwork, any new or up comming parts for the 2nd gear grind?
Old Jul 8, 2003 | 07:53 PM
Jason B's Avatar
Ok, so all I do is give my dealer that TSB number and they will automatically know about the updated part? Do I need to confirm anything else with them?
Old Jul 9, 2003 | 09:31 AM
Jason B's Avatar
Bump.
