Anybody know off the top of their head where I can get a signal for...
Old Mar 9, 2004 | 06:23 AM
DongTran's Avatar
Default Anybody know off the top of their head where I can get a signal for...
ignition and handbrake? THANKS!
Old Mar 9, 2004 | 06:42 AM
ruexp67's Avatar
Ignition, on the fuse block would probably be the easiest. Hand break, the only place I know of is in the center console. Not sure where it runs from there.
Old Mar 9, 2004 | 07:04 AM
bobby's Avatar
12volts white (x2) + ignition harness
Starter blue/white + L of column, lt blu 24P plug
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition N/A
Accessory white/red + ignition harness
Second Accessory N/A
Keysense red/white - ignition harness
Power Lock pink/black 5wi keyless entry module
Notes: The keyless entry module is located in the driver kick behind the start button.
Power Unlock yellow/green & pink/blue 5wi keyless entry module
Lock Motor pink/black 5wi keyless entry module
Unlock Motor yellow/green 5wi keyless entry module
Parking Lights+ red/black + keyless entry module
Parking Lights- blue - headlight switch
Hazards same as turn signals
Turn Signal(L) green/red + steering column
Turn Signal
Old Mar 9, 2004 | 10:30 PM
DongTran's Avatar
wow jeez haha thanks
bb_chris1688
Jan 21, 2014 12:17 PM
afwfjustin
Sep 25, 2012 11:32 AM
HankookS2K
Jul 28, 2012 03:45 PM
124Spider
Nov 29, 2004 10:13 AM
VTECorona
Aug 25, 2004 03:55 PM
