viper 5407v install
Old Jan 17, 2014 | 05:14 PM
bb_chris1688's Avatar
Default viper 5407v install
hello,
I am having a huge brain spasm over this remote start install. I have seen many non remote installs but I would like to get mine to remote start so I am not interested in removing wires for the non remote start.
here is my questions I need answers to for wiring/ what I have so far.
remote start 10 pin connector h3
H3/1 PINK-IGN 1 INP/OUT:BLACK/YELLOW
H3/2 RED/WHITE-FUSED 30A IGNTION 2/FLEX RELAY INPUT 87:????
H3/3 ORANGE-ACC: WHITE/RED
H3/4 VIOLET-STARTER OUTPUT; CUT BLUE/WHITE
H3/5 GREEN-STARTER INPUT: CUT BLUE/WHITE
H3/6 RED FUSED 30A IGNITION 1 INPUT: WHITE
H3/7 PINK/WHITE- IGNITION 2/ FLEX RELAY OUTPUT:????
H3/8 PINK/BLACK-FLEX RELAY INPUT 87A KEY SIDE:????
H3/9 RED/BLACK-FUSED 30A ACC/START INPUT: ????
ANY HELP FOR MY ?'S WOULD BE VER APPRICIATED THANK YOU
Old Jan 17, 2014 | 08:09 PM
mD5's Avatar
mD5
Red black needs 12v flex relays are for different applications. Per say an ignition that reads open at rest. My car remote starts, I installed mine. If it weren't so cold outside I'd take a picture for you
Old Jan 21, 2014 | 12:17 PM
Mighty_Mouse_Ep's Avatar
So anything with a fuse on it should go to a constant 12v input. Your pink white wire should go to a black/red wire on the s2k's ignition harness. Kinda messy but here are the color codes and location for an s2k.
Battery WHITE OR WHITE/BLACK (+) IGNITION SWITCH HARNESS
Ignition 1 BLACK/YELLOW (+) IGNITION SWITCH HARNESS
Ignition 2 BLACK/RED (+) IGNITION SWITCH HARNESS
Accessory 1 YELLOW (+) IGNITION SWITCH HARNESS
Starter 1 BLUE/WHITE (+) AT PUSH BUTTON START SWITCH
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense RED/WHITE (-) AT KEYLESS MODULE BEHIND DRIVER SIDE DASH
Tachometer BLUE (AC) 2 PIN PLUG ON DRIVERS SHOCK TOWER
Crankshaft Sensor BLUE (AC) AT ECM MODULE IN DRIVERS KICKPANEL BEHIND HOOD RELEASE
Camshaft Sensor GREEN (AC) AT ECM MODULE IN DRIVERS KICKPANEL BEHIND HOOD RELEASE
Speed Sense BLUE/WHITE (AC) IN HARNESS TO GAUGES
Parking Lights RED/BLACK (+) AT KEYLESS MODULE BEHIND DRIVER SIDE DASH
Brake Lights WHITE/BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights GREEN/BLACK (+) IN HARNESS IN DRIVER SILL PANEL
Horn ORANGE (-) AT KEYLESS MODULE BEHIND DRIVER SIDE DASH
Rear Defrost YELLOW/BLUE (-) AT REAR WINDOW DEFROST RELAY NEAR KEYLESS UNIT UNDER DRIVER SIDE DASH
AusS2000
Sep 4, 2013 10:29 PM
HankookS2K
Jul 28, 2012 03:45 PM
EOE
Jun 22, 2011 11:35 AM
HOTRODS2000
Nov 29, 2004 12:32 PM
