Rear View Mirror Installation
Old May 30, 2004 | 05:15 PM
jchung's Avatar
Default Rear View Mirror Installation
I was washing my front windshield today and my rear view mirror just fell off as I was trying to clean the area around the mirror mount.
I dont have a clue on how to put it back together. I have the mirror, the spring, and the metal washer peice. I'm pretty sure the metal is what slides into the mount that is on the window. I dont know if I'm missing any other parts since I didnt see the who mirror actually fall.
Can anyone help me out w/ this? Thanks a bunch.
-jimmy
Old May 30, 2004 | 05:18 PM
Intrepid175's Avatar
[QUOTE]Originally posted by jchung
Old May 30, 2004 | 05:21 PM
frycow's Avatar
Consider get an auto-dimming mirror with fancy features to replace your current rear-view mirror. If mine fell off, I certainly would.
Old May 30, 2004 | 05:22 PM
jchung's Avatar
The mount that is attched to the window did not fall off. That is still on the windshield.
Old May 30, 2004 | 05:25 PM
VTEC4-2's Avatar
So is the "mount" still on the window? If them metal piece came off the window, you will need to have a glass installer EPOXY it back on (better than adhesive).
I'll go get my mirror assembly (it's out of the car) and take some pictures so you can see how it goes back together.
Old May 30, 2004 | 05:28 PM
jchung's Avatar
[QUOTE]Originally posted by VTEC4-2
Old May 30, 2004 | 05:29 PM
Oh, that's different. All the car's I've worked on in this area, had some kind of set screw, usually an allen head set screw, that locked the mirror on to the metal piece that glued to the glass. Does you're have this? If so, just put the mirror back on and tighted the set screw. It doesn't need to be "real" tight, just a little snug.
Good luck,
Steve R.
VTEC4-2's Avatar
OK hang in there it will be just a minute....
Old May 30, 2004 | 05:35 PM
VTEC4-2's Avatar
Ooops, I think I showed the metal button upside down
The pictures should help anyway...
Old May 30, 2004 | 06:06 PM
jchung's Avatar
fantastic.
i knew i had to take the screw off to put the washer in.
its screwed on pretty tight.
thanks again vtec4-u!!
