Speed Bleeder thread sealant: any alternative?
Old Jun 12, 2004 | 09:18 AM
rlaifatt's Avatar
Default Speed Bleeder thread sealant: any alternative?
Would teflon tape work, or is there an equivalent product to Speed Bleeder's red sealant that would be available in a local autoparts store?
Old Jun 12, 2004 | 10:29 AM
krazik's Avatar
Administrator
I used teflon tape.
I sugest throwing them away and going back to stock. I never got a good bleed w/ them.
Old Jun 12, 2004 | 11:34 AM
cdelena's Avatar
I switched to the solo bleeders after problems with the thread sealant. They have an external valve and longer threads so they don't rely on the sealant.
Old Jun 12, 2004 | 11:43 AM
rlaifatt's Avatar
Ry, I've never had a problem with Speed Bleeders for two years (no leaks, no air), and I bleed at every track event and sometimes after, so a lot. The reason I am having to replace the sealant on one is because I replaced a caliper and am reusing the old Speed Bleeder (once you remove it completely the sealant is shot). I'll try the teflon tape, thanks.
Old Jun 12, 2004 | 12:26 PM
krazik's Avatar
Administrator
just about everyone else has had problem w/ the speed bleeders sealing
I get a much stiffer pedal from OEM bleeders, but yes it does require 2 people to bleed.
Old Jun 12, 2004 | 03:42 PM
Voodoo_S2K's Avatar
I haven't had any problems with the Speed Bleeder myself, but since we have a real power bleeder now, I'm going to go back to stock. Pipe thread sealant should work fine. Put some on and let it dry.
Old Jun 13, 2004 | 06:06 AM
Road Rage's Avatar
The hardest pedal I have got on my older cars has been a reverse bleed from the Phoenix Systems V-12. It pushes the air where it wants to go - up.
Old Jun 14, 2004 | 08:55 PM
M5150's Avatar
i recently used a pnuemativac which is basically a mightyvac that is air powered along with teflon tape and it gave amazing pedal feel i must say.
Old Jun 14, 2004 | 09:05 PM
Voodoo_S2K's Avatar
My roommates and I just got one of these . I can't wait to try it out this weekend. The only bad part is buying the 3 gallons of ATE to fill it.
Old Jun 14, 2004 | 09:17 PM
Asura's Avatar
I have a Vacuum bleeder. It works great. I never got the speed bleeders to work right from the beginning so I tossed them. Stock bleeders work for me.
