Gateway S2000 Owners Members for St. Louis MO and area.
Suffering from the 2nd to 3rd grind
Old Oct 7, 2004 | 11:43 AM
8BALL's Avatar
Default Suffering from the 2nd to 3rd grind
For the past couple of weeks my tranny has been showing the symptoms of the second to third grind posted in many threads on this board. Replaced my tranny fluids with Red Line MT-90 Manual Transmission Lubricant and MY01 shifts like butter now. An unbelievable difference with a very smoooooooth shift! While I had the car up, I also changed out the Diff fluids using Lubrication Engineers LE-607 90W Almasol Gear Oil.
I was really amazed when I took it for a drive after the fluid change-out. What a difference.
Old Oct 7, 2004 | 01:18 PM
hyedracyl's Avatar
Mike,
Wasn't one of those fluids not supposed to be changed away from the Honda fluid? Keep me posted as I need to do the same thing personally. Just turned 26K miles on the car this morning on my drive in!
Oh, and the mystery Spa Yellow car that I saw at the gym turned out to be owned by a friend of mine. They bought a Miata when I had mine, now I bought an S2000 and then they turned around and did the same!
Greg
Old Oct 7, 2004 | 01:46 PM
8BALL's Avatar
Originally Posted by hyedracyl,Oct 7 2004, 04:18 PM
Mike,
Greg
I've heard both sides of the story, so I decided to make the change from Honda fluid to a higher performance fluid. Guaranteed that I will keep my eye on it closely.
About the SPA yellow friend of yours... Get them interested in this club. We need to get our membership, events, meets moving.
Was thinking of getting some cards printed up. Have seen seeing quite a few S's around the area. Think they just don't know about us.
Old Oct 8, 2004 | 09:21 PM
folex187's Avatar
My gear changes are anything but smooth. I would like to see how this stuff works over time and then give it a try.
Old Oct 10, 2004 | 03:09 PM
8BALL's Avatar
Put 100 miles on it this weekend. I don't know if it's my imagination, but it even feels smoother now.
I forgot to mention that I also switched ot the copper and steel washers in the Diff. Was forced to purchase 3 pair. I have two set available for anyone that wants the. $1 per set (2 washers; 1 copper/1 steel)
Old Oct 10, 2004 | 07:55 PM
bills2k_2001's Avatar
Mike, just order some RedLine for my car. Wish me luck
Thanks for bringing the Plexus by. I don't think everyone knows how hard you work to make this site work. Thanks!!!!!
Old Oct 14, 2004 | 05:14 AM
8BALL's Avatar
I've put on 250 +/- miles on the car since the fluid change and it is still shifting very smoothly.
Bill... Let me know if you need a fluid pump to change out your fluid when it arrives. You are more than welcome to use mine. Using the "tape tube to bottle" approach is a bit messy.
Old Oct 14, 2004 | 08:32 AM
folex187's Avatar
How long does it take to change out the fluid? Is it hard?
Old Oct 15, 2004 | 10:56 AM
8BALL's Avatar
Took about 20 minutes for the tranny and another 20 minutes for the differencial. Since I had the car up anyway, I decided to do both and save some time. It's pretty much a piece of cake to do. I have all the tools, jacks, fluid pump, new washers to get this done.
Since Bill already ordered the Tranny fluid, and you and Greg are thinking about it... I think it's time to have an Install Day or should I say Fluid changeout day.
Thoughts...
Here are some threads which I think will answer your questions.
First read this: Tranny Grind
Then this:Tranny Fluid Change
Then this:Diff Fluid Change
madness
Nov 21, 2009 10:01 AM
Crafte
Dec 29, 2006 08:27 AM
Saab9-3
Apr 24, 2003 07:46 PM
golfnut311
Dec 1, 2002 03:07 PM
OneQuickS2K
Jun 7, 2002 01:51 PM
