Engine block adapter
Old May 14, 2005 | 11:29 PM
C6400hp's Avatar
Default Engine block adapter
As the title states does anyone have an accurate torque spec for the Greddy engine block adapter?
Old May 15, 2005 | 10:06 AM
C6400hp's Avatar
Old May 15, 2005 | 12:55 PM
AJ PwR's Avatar
I am curious, what is a Greddy block adaptor ? You mean the block brace ? Or the oil sandwich adaptor ?
Old May 15, 2005 | 01:19 PM
Stratocaster's Avatar
It is the oil sandwich adaptor. If I could find my helms, I would post it. It would be the same spec as the oil filter. I think it is 23ft lbs.
Old May 15, 2005 | 04:01 PM
C6400hp's Avatar
I tightened it to 20# the first time ...It came loose after about 150 miles... I guess I will try some blue loctite and 30 FT LB.
Old May 15, 2005 | 07:00 PM
Elistan's Avatar
Brian,
Does this part go between the engine block and the oil filter? If so, and this is just a WAG, but have you made sure that two rubber gaskets didn't end up getting sandwiched together? I've read several reports of a removed oil filter leaving is gasket behind, and when the new filter with its own gasket were installed, the filter worked itself loose in relatively short order.
Old May 15, 2005 | 07:09 PM
C6400hp's Avatar
Didn't think about that. Thanks for the tip, I'll check it out.
zeroptzero
Dec 21, 2011 06:46 PM
Wayners
Sep 13, 2010 05:27 PM
synapse
Jun 18, 2008 10:43 AM
folex187
Jan 12, 2006 09:20 PM
ImportSport
Jun 1, 2005 11:06 PM
