Engine block adapter
Originally Posted by AJ PwR,May 15 2005, 02:55 PM
I am curious, what is a Greddy block adaptor ? You mean the block brace ? Or the oil sandwich adaptor ?
Brian,
Does this part go between the engine block and the oil filter? If so, and this is just a WAG, but have you made sure that two rubber gaskets didn't end up getting sandwiched together? I've read several reports of a removed oil filter leaving is gasket behind, and when the new filter with its own gasket were installed, the filter worked itself loose in relatively short order.
zeroptzero
Dec 21, 2011 06:46 PM
