Maintenance Req'd light....
Old Sep 25, 2001 | 08:14 AM
HeNeSSeY's Avatar
Default Maintenance Req'd light....
Just wondering, when you guys start your engines, does your "maintenance required" light flash a while before disappearing? I just noticed this because one time I was driving, and the maintenance light started flashing, then turned off. And now I dont know if that light should flash when starting the car. It flashes for like 5 secs before shutting off...
I'm due for an oil change, that wouldn't have anything to do with it... will it? Thanks....
Old Sep 25, 2001 | 08:19 AM
turbo_pwr's Avatar
http://www.s2000online.com/faqs/showfaq.ph...?threadid=17415
Old Sep 25, 2001 | 08:25 AM
HeNeSSeY's Avatar
Thanks man... I just reached 6000 miles though... I guess near 7000 it will go off.. thanks again..
Old Sep 25, 2001 | 08:47 AM
smyroad's Avatar
The light will keep blinking until you reach the maintenance mileage and it will light solid. Who ever does the maintenance will reset it, or you can follow the instructions in the faq link :
https://www.s2ki.com/faqs/showfaq.php?threadid=17415
Old Sep 25, 2001 | 03:25 PM
temin's Avatar
The FAQ needs to be fixed a tiny bit.
The secret is holding the reset button and turning the key to the next position. It does not specify that in the manual
You don't turn the key from the "lock" position to the "accessory" position. It needs to go all the way to "on." Oh, this IS specified in the manual. Mine says so on page 63, I think.
After turning the key to "on" I had to hold down the "trip" button longer than 15 seconds. Did it take this long for anyone else? I know 15 seconds isn't all that long, but when you're expecting the light to just go away after 2 or 3 seconds 15 is an eternity
Temin
Old Sep 26, 2001 | 04:18 AM
vmb's Avatar
vmb
Just had an oil change done at 7200 miles by the dealer, shouldn't they have reset this light? It still blinks at start-up. I don't believe they actually changed the oil
Old Sep 26, 2001 | 04:56 AM
temin's Avatar
My dealer didn't reset the light, but the oil did get changed. See if your oil is clean if you're worried.
Temin
DangerZone9K
Apr 22, 2009 05:01 PM
emrillive
Oct 21, 2004 12:42 PM
03 S II K
Jan 13, 2004 11:00 PM
bboersma
Nov 13, 2002 11:39 AM
Relson
Jul 30, 2001 04:10 AM
