Adjusting head light height?
Old Aug 6, 2005 | 06:25 AM
Ponch's Avatar
Default Adjusting head light height?
When i first got my 2000 used it had been repainted. I guess when they put the front back together they didnt adjust the driverside light correctly because it is higher than the passenger side. I get flashed all the time because it is aiming in other peoples faces. Is it pretty easy to adjust? I am going to attempt it today, thanks guys.
Old Aug 6, 2005 | 05:12 PM
xviper's Avatar
Your owners manual will show you how with pictures and instructions. It involves parking the car on a level surface in front of a flat, vertical wall. The adjuster is accessed from within the engine bay and involves turning with a screw driver.
Old Aug 6, 2005 | 05:29 PM
terahertz's Avatar
i would like to know how to do this as well.. my 2005 manual does not have these instructions. it says that the headlight alignment should be performed by the dealer. anyone able to post some scans of the manual?
Old Aug 6, 2005 | 06:24 PM
xviper's Avatar
Bastids! Trying to get a little more business for their dealers.
Ground must be level, wall must be vertical.
Park car with front of headlight lense exactly 25 ft. from wall.
Measure the height of the headlight (center of lens) from the ground at the car. Transfer this measurement to the wall and draw a line.
You headlights' lowest illumination line should be 2.1" BELOW this line.
On each fender wall (inside the engine bay), just behind each headlight, you will see a round wheel-shaped adjuster know. This know has a sort of "2 pronged" fork situated over the splines on that wheel. Put a flat screwdriver into the middle of that fork to flip the splines (and the wheel) one notch at a time in the desired position to raise or lower the headlite beam.
You cannot adjust the headlights from left to right without modifying the actual headlight mounts.
Old Aug 6, 2005 | 09:30 PM
Picturepro's Avatar
I have a 2005 and had to raise the lights....
5/16 little socket, small swivel to a 6" extender
with a rachet
get a little flash light... the screw in the cubby hole
2 handed opperation, just look for the 5/16th head
clock wise to raise... my lights took 6-8 turns
to check lights.... park 20-30 feet away from closed garage
make a referance where the light are... then screw it a couple times
go for a test drive... and readjust if needed
Old Aug 7, 2005 | 11:35 AM
Ponch's Avatar
Thanks guys.....will this move the whole assembly? the whole light looks like its pointed at an angle causing a gap at the bottom of the light. I will try it later to see if it adjust the gap.
Old Jan 18, 2010 | 05:18 PM
charliele729's Avatar
[QUOTE=xviper,Aug 6 2005, 06:24 PM] Bastids!
Old Jan 22, 2010 | 06:37 PM
Volked_S's Avatar
Lower step? Lol that would be pointing to the sky no?
R23USS
Apr 13, 2018 10:43 PM
SilverS2kF22C1
Mar 12, 2010 05:56 AM
dezymond
26
Aug 28, 2009 12:32 PM
uncleben
Dec 21, 2007 07:46 PM
hemanuel
May 11, 2001 03:26 AM
