Headlight Control unit
Old Mar 11, 2010 | 05:13 PM
SilverS2kF22C1's Avatar
Thumbs up Headlight Control unit
Cliff notes: Where can I but ONE headlight ballast for 2005 S?
So I had an issue late last year with the Driver's side low beam flickering and not coming on. Usually a good 'ole "Fonzarellie" tap on the light would turn it on. This year when I took the car out of storage I must have lost my touch.
I skimmed through the factory manual and check the relays and fuses for the headlight, both were OK. I purchased a bulb, thinking and hoping that is all it was...
I installed the new bulb this evening and no dice, light still wouldn't turn on.
Well now it is the igniter or the ballast... I took the ballast from the passenger side swapped it with the drivers side and vice versa... Whaaa BAAMMM! Drivers side headlight worked passenger side didn't... So the ballast is the problem...
Great...
I poked around a bit on the net and every place I come across only will let me buy 2 not 1... But they aren't as expensive as I thought they would be but expensive when they only let you buy 2 at a time!
Anyone know where I can pickup a single ballast for a 2005 S?
Thanks!
Old Mar 11, 2010 | 05:28 PM
Found one that will sell one....
Anyone know how these guys are?
http://www.hondapartscheap.com
Old Mar 11, 2010 | 09:13 PM
sillyboybmxer's Avatar
you can go to suvlights.com too or head over to hidplanet.com and check the classifieds. lots of good stuff over there
Old Mar 12, 2010 | 05:56 AM
viets2000's Avatar
they show up occasionally in the for sale forums
Richvow
Mar 31, 2016 01:47 PM
s2kev
May 21, 2006 01:22 PM
trick408
Apr 16, 2006 06:47 PM
anthonys2k
Jan 25, 2005 06:52 PM
anishd
Jun 17, 2004 07:55 PM
