Radio Problem
Old Sep 25, 2005 | 06:55 PM
SORPASSO's Avatar
Default Radio Problem
My radio/CD player stopped working and the anti-theft light keeps blinking. There is no display, codes or anything...any ideas?
Old Sep 25, 2005 | 07:07 PM
converted's Avatar
check the fuse for the power accessory outlet. i had a similar experience and that fuse was the culprit. the fuse is somehow tied to the radio.
Old Sep 26, 2005 | 07:15 AM
xviper's Avatar
Actually, the audio system on this car runs through 3 separate fuses.
Old Mar 2, 2009 | 10:18 AM
ok2k's Avatar
What THREE fuses does our radio run off?
I've checked the 10 and 15 ACC and Radio fuses and they are not blown - but my radio still doesn't work (No mute light even - though the 'Anti-Theft' light still works and it still spits out/accepts CDs)
Thanks for any insight into the elusive 3rd fuse...!
Old Mar 2, 2009 | 04:14 PM
Utah S2K's Avatar
Have you recently disconnected the battery? If so then the unit has reset and is looking for an authentication code. The AP1 radios have an anti-theft system which requires you re-enter the code whenever the unit loses power (i.e. is stolen).
If that's not it then I have no idea......
Utah
Old Mar 2, 2009 | 09:18 PM
RFCR's Avatar
You may need to unlock the radio unit. Code came with your vehicle manuals or you can retrieve at your dealer with your VIN, provided your radio is original.
Old Mar 3, 2009 | 04:13 AM
S2kRick's Avatar
Also, look for a sticker in your glove box, or secret compartment. Mine was on the inside of the lid
Old Mar 3, 2009 | 06:21 AM
JackS's Avatar
If all wires are connected including the antannea, I think your going to either have to fix or replace the radio. A long shot might be the antenna. My question is- Does this radio power-up regardless of weather a radio signal is detected? If not, maybe a bad antenna?
Old Mar 3, 2009 | 11:33 AM
oth's Avatar
oth
on an AP1,
fuses 9 & 22 are for the "audio unit" and #23 is for the "audio unit light"
farineh
Sep 12, 2010 07:41 AM
Antonio'S2K
Aug 25, 2010 03:37 AM
Heartless
Oct 14, 2005 07:35 AM
gbuka
Apr 27, 2005 10:45 AM
s-duces
Jun 30, 2003 09:01 PM
