Use Radio Shack relay for Amp Remote?
Old Nov 14, 2001 | 03:41 PM
JL's Avatar
JL
Default Use Radio Shack relay for Amp Remote?
Hi,
I am finally going to get a 4-ch amp to drive the fronts and the rear spearkers. One of the side benefit that I was hoping to get from this is to enable the mute button. (I have PAC to JVC HU already. JVC does not have the mute lead-in.)
Question: do you think I can use the same scheme mentioned at few places that uses Radio Shack Reed Relay (part# 275-233) to the cell-phone mute, for controlling the Amp's remote signal wire?
If this works, then I don't mind the disadvantage of keeping the HU running while the amp is powered off and on for the mute.
Regards,
JL
Old Nov 14, 2001 | 05:36 PM
MacGyver's Avatar
As long as the current rating of the relay isn't exceeded, the same scheme is applicable.
Old Nov 15, 2001 | 04:36 AM
Barry in Wyoming's Avatar
Here's the scoop on the Radio Shack 275-233 relay from an email I sent Dan (Macgyver) months ago:
[QUOTE]This relay is perfect for our mute button application, as far as I can tell.
Old Nov 15, 2001 | 01:25 PM
modifry's Avatar
Honorary Member
Most amps are designed to be "turned on" by a low current signal from a head unit or other electronic output. I'd be surprised if it took more than a few milliamps to turn on an amp.
Goferit.
Old Nov 15, 2001 | 09:26 PM
JL's Avatar
JL
Thanks for the info.
The amp is Soundstream A4. The manual doesn't say what the load is on the remote line. I wasn't worried about blowing the relay when I test. I was more worried about frying it later inside the dash.
Anyway, I will just go for it as Modifry says and see how it works.
Old Nov 18, 2001 | 07:46 PM
JL's Avatar
JL
I installed a relay with the new amp. I had to use Radio Shack SPDT Miniature PC Relay #275-248A. The 275-233 had the "Normally Open" only and I needed "Normally Closed" for the Amp remote signal. (Duh!) The muting button is working now.
Thanks for your help.
Old Nov 18, 2001 | 08:40 PM
I'm glad you got it working.
offroad2000
Jun 2, 2008 02:20 PM
Edlover
Dec 10, 2006 10:13 PM
J Nick
Nov 19, 2003 11:44 AM
145
Jul 9, 2002 06:06 PM
Silver S2k Guy
Oct 11, 2001 07:34 PM
