View Poll Results: Vortech owners have you broken a bolt or more on your setup?
No broken bolts, checked today
23.53%
Yes I have broken the bolt(s)
41.18%
No, I have not checked
26.47%
Yes, I broke the idler pulley bolt
2.94%
Yes, I broke the idler pulley bolt and Vtec solonoid bolts too.
5.88%
Voters: 34. You may not vote on this poll
Vortech broken Vtec soloniod bolts
Old Jun 7, 2006 | 04:22 PM
Sideways's Avatar
Default Vortech broken Vtec soloniod bolts
Well, after giving some people a hard time about this subject, we found a broken Vtec solonoid bolt on my car today. I can see the end of it in the head but it is broken off flush or slightly in the head. I may need to easyout the bolt end from the head and since there is very little clearance, it looks like a major PITA. I'll post pictures in the next post.
Old Jun 7, 2006 | 04:26 PM
Sideways's Avatar
Notice the allenhead bolt on the right and the empty hole under it.
Close up
One potential solution, Titanium bolts.
Old Jun 7, 2006 | 04:28 PM
ex-eclipse's Avatar
Did your car come from the factory with allen headed bolts?
If it is broken off flush with the head, I have had good luck with wire welding a smaller bolt onto the end of the threads so that you can back them out with a wrench.
Old Jun 7, 2006 | 04:41 PM
Slows2k's Avatar
The OEM bolts have a 10mm head and are approx 1" shorter than the vortech supplied bolts.
I'll take a look at mine now.
Old Jun 7, 2006 | 04:46 PM
Slows2k's Avatar
Just checked, all bolts in place.
Old Jun 7, 2006 | 04:50 PM
casterdog's Avatar
Not only did I break that bolt, I broke the one on the idler pulley, cracked the horizontal braket, damaged the vtech spacer brackets facing and cracked a piece off the timing chain cover.
Old Jun 7, 2006 | 04:51 PM
Slows2k's Avatar
How did you do all of that?
Old Jun 7, 2006 | 05:07 PM
slimjim8201's Avatar
Sounds like a grenade went off in your engine bay.
Old Jun 7, 2006 | 05:08 PM
casterdog's Avatar
Still trying to figure it out. The SC lost the input bearing and so it gets to be a game of which came first. Did a bolt go causing the bearing to take excess load and fail, did the bearing failure increase the load causing a bolt to go or?
Old Jun 7, 2006 | 05:59 PM
John_Z's Avatar
My SC is temporarily off the car, no broken bolts or signs of iminent failure. I forget what it is, but there is a specific torque for required to hold the solenoid assy on, but it's not much. Must be the vibration, long stud length, and weight put on those bolts.
