bumper plug issue
Old Aug 4, 2006 | 11:01 AM
KGB's Avatar
KGB
Default bumper plug issue
Picked up new '06 and the dealer put the front plate on. No biggie I took the plate off and picked up some OEM bumper plugs. When I was putting them in the car on one side the female metal threaded part popped out inside the bumper.
Looks like there is no easy way to reach it without taking the bumper apart. I did search on this a little and it looks to be a relatively common issue. I'm not the only one with this problem... So how do I fix it?
Take it to the dealer? Take it apart myself? It's pretty annoying to be running around w/ one plug and one hole inside which there is this metal thing sitting crooked. Damn what posseses dealers to put on that ghetto front plate? They should just save themselves the effort.
Drew
Old Aug 4, 2006 | 12:31 PM
frofro24's Avatar
I would call the dealership and explain the problem, maybe they will do it at no cost. Can't hurt to call.
From what it sounds like, you said it is sitting crooked, if you can see the threads try getting a long screw and thread it in and try to pull it back into place.
Well, good luck.
Old Aug 4, 2006 | 12:51 PM
KGB's Avatar
KGB
do you know how it's attaches on the other side? does it snap into place, glues into place, etc. i can try that w/ the screw see what happens...
Old Aug 4, 2006 | 04:25 PM
GotRPMs's Avatar
Same thing happened to me, and i ahd to take off my bumper. Not hard at all, jsut spend some time re aligning it and you will be fine. Check out www.ricks2k.com for bumper removal instructions. They will be under instalations, then headlight diffusors.
Old Aug 4, 2006 | 06:05 PM
frofro24's Avatar
Mmm not too sure how it attaches. I would figure it snaps into place. Post and let me know if it works.
Old Aug 5, 2006 | 01:00 AM
NFRS2kSi's Avatar
if u can't reach it.. then screw the bolt and pull it out.
Old May 6, 2008 | 05:27 PM
iwantyourcar's Avatar
hate to bring a topic back from the dead, but I just had this same problem...
Old May 7, 2008 | 10:28 PM
SDSILVERM3's Avatar
Same thing happened to me two weekends ago. Couldn't help but laugh because it was pretty lame to have it happen.
Ended up having a friend fish out the threaded part and used double sided tape for the remaining bumper plug. Wasn't worth the time taking off the bumper.
TheGingernator
Dec 27, 2014 07:13 PM
Euroflavor
Apr 11, 2009 09:36 AM
SPFSkyline
May 11, 2008 09:02 AM
mooshy_sushi
Mar 18, 2006 07:13 AM
GotRPMs
Sep 16, 2005 11:52 AM
