"Skip shifting is brutal" ?!
Old Oct 14, 2006 | 12:00 AM
Boofster's Avatar
Default "Skip shifting is brutal" ?!
Straight from the 01/06 ServiceNews bulletin:
Skip Shifting Is Brutal on
Synchronizers
Gear ratios in 6-speed manual trannies are spaced
close together so you can keep the engine speed
in its optimum range for max power and
acceleration. Shifting to the next higher or lower
gear in a close-ratio tranny causes small changes
in engine speed.
Shifting a close-ratio tranny through its gears by
the numbers puts a very small load on the
synchronizers since they only have to make small
changes to the speed of the mainshaft and the
clutch disc.
Some drivers, though, like to skip shift so they
don
Old Oct 14, 2006 | 12:08 AM
hpark's Avatar
i'm assuming double-clutched, rev-matched shift would wear the synchros less on "skip shifts"?
Old Oct 14, 2006 | 12:22 AM
SpitfireS's Avatar
Shifting from 2nd (redline 9k rpm) to 3rd is about 2700 rpm drop.
Shifting from 2nd (redline 9k rpm) to 6th... is about 5000 rpm? drop.
That means 6th gear synchro has to deal with that.
Shifting from 5th (redline 9k rpm) to 6th is about the same 2700 rpm drop, that is what the 6th gear synchro was designed for.
I may have the revs wrong.. it is about the principle.
Old Oct 14, 2006 | 12:30 AM
AlX Boi's Avatar
When I'm slowing down at a red light and say I'm in 4th, I keep it in 4th instead of neutral or downshifting. Sometimes the light changes to green before I stop, so I shift from 4th to 2nd, but my speed is totally in 2nd gear range. That's cool right?
Old Oct 14, 2006 | 12:36 AM
gtfour43's Avatar
Originally Posted by AlX Boi,Oct 14 2006, 12:30 AM
When I'm slowing down at a red light and say I'm in 4th, I keep it in forth instead and neutral or downshifting. Sometimes the light changes to green before I stop, so I shift from 4th to 2nd, but my speed is totally in 2nd gear range. That's cool right?
Yep. Thats fine.
Old Oct 14, 2006 | 02:13 AM
INDYMAC's Avatar
Nothing new here. This has been discussed many times and members of this forum have been warned about the consequences of skip shifts (as well as mis-shifts) since I joined this Forum almost 3 years ago. Why do people still think it's OK to do this?
Old Oct 14, 2006 | 03:29 AM
AlX Boi's Avatar
Because owners of S2000s aren't static. There are new owners all the time, so we need to be chills about inexperienced people. I still don't know a lot of stuff after 5 months of ownership. I'm sure xviper, God bless his soul, doesn't know every single detail either.
The search button really isn't all that useful. It finds a lot of erroneous topics, so it does take some time to find exactly what you want.
Old Oct 14, 2006 | 06:25 AM
hondabert's Avatar
I guess I don't understand this fully... why wouldn't it be ok to skip shift as long as you're matching revs and speed appropriately?
Old Oct 14, 2006 | 07:04 AM
Wildncrazy's Avatar
And also because it is OK to do it on virtually every other transmission in existence.
I have been guilty of skip shifting my whole life and I have never had a problem in any transmission ever!
This is just a Honda thing (design flaw) and therefore people not indoctrinated are doing what comes naturally.
bluegas68's Avatar
[QUOTE=AlX Boi,Oct 14 2006, 06:29 AM]The search button really isn't all that useful.
