Checking Valve Spring Retainers
Old Oct 29, 2006 | 06:42 AM
mikdys's Avatar
Default Checking Valve Spring Retainers
5mm allen key to remove the spark plugs cover
Remove the ignition coil retaining bolts with a 10mm ring spanner (or 10mm socket if you have one)
Lift the coils up slightly and remove the connectors, then the coils
Remove the plug from the exhaust cam angle sensor
Remove the retaining bolt (10mm head) then the sensor
This is what it looks like removed
Pull the spark plug/sensor loom away and rest on the top of the exhaust manifold
Remove the two breather hoses and dip stick (pliers needed for the clips on the front hose)
Remove the plug from the inlet cam angle sensor and remove the sensor
Remove the five cam cover bolts (10mm heads -you can just about get away with a small ring spanner but a socket makes the job much easier). Remove the chrome washers and rubber seals underneath (don't leave these on or they may fall in the top of the engine when you remove the cover!).
Pull the throttle cable out its retaining clips to allow more room to remove the cam cover
Ready to remove - a wooden clothes peg is useful to pry the cover away from the head by inserting in the gap between the two and twisting (the wood won't damage the aluminium surfaces). Be careful with the seals around the spark plugs when removing the cover and pull it up gently and slowly.
The tools on the right (10mm ring spanner, 5mm allen key and a pair of pliers) are all that's needed.
These make the job a lot easier though
Check this post for what you are looking for:
https://www.s2ki.com/forums/index.ph...c=399357&st=25
My inlet valve retainers look OK:
Easier with an inspection mirror
What was I saying about dealers? (4,000 miles since a "major service" when the valve clearances were "supposed" to be adjusted and I found some inlet valve clearances very tight at 6 thou and the spark plug wells full of oil and the seals looking like this):
Nicely ripped - top job chaps!
This is what it should look like
I'm going to have to order some seals and fit them (not a problem as the car is not a daily driver and is kept in a garage).
Reassembly should be a reverse of the above, taking care of the rubber seals and oiling them prior to assembly (don't do it the "dealer way"). The cam cover bolts should not be over tightened (just "rested").
Old Oct 29, 2006 | 06:56 AM
Blurter's Avatar
Excellent job and instructions
Old Oct 29, 2006 | 07:18 AM
eSeM's Avatar
My seals were the same
The seals that I replaced them with are a different design so this must have been a common problem with the older seals.
Old Oct 29, 2006 | 09:00 AM
mikdys's Avatar
Sounds like a few parts have been improved during the early service life of the car and these seals also (somebody told me once that the best time to buy a car model - if you are mainly interested in reliability - is just before a new model replaces it - I think that is probably true).
The thing that concerns me though is that the dealer who last worked on my car replaced the cam cover with the seals in this state.
Now the car is getting older I'm seriously thinking of servicing it myself, why do I need a Honda service history if I'm not planning on selling it and when I can both save money and be confident the work has been done properly? All I feel I ever got from dealers for
Old Nov 10, 2006 | 10:44 PM
zagamuffin's Avatar
very good thread
Old Nov 18, 2006 | 08:34 AM
stocky's Avatar
I dont think you can assure the good condition of the valve retainers just by looking at them.
They may hav e"inside" cracks (fissures)
Mullallyman
Mar 6, 2024 09:30 PM
nibble
Sep 3, 2023 11:44 AM
Chris_Lum
May 22, 2011 03:04 PM
ryanfeldman
Jul 25, 2007 12:42 AM
Pickle Boy
Mar 16, 2002 10:28 AM
