Remove Valve Cover
So I am thinking about getting some things in my engine bay power coated. One of those thing is the valve cover. I am wondering if anyone has taken it off before, how difficult it is, and if there is a "how to" somewhere on the boards. Can anyone help me out? Thanks.
Allen key and a 10mm socket/wrench.
Disconnect battery
Unclip sensors/vac lines
Remove dip stick
Remove hex bolts/spark plug cover
Unscrew 10mm coil bolts
Remove coils
Remove 5 bolts holding valve cover down
Peel it off
Disconnect battery
Remove dip stick
Remove coils
Peel it off
Originally Posted by LemurFaktore,Jul 24 2007, 08:47 PM
makes it faster if you use a makita 3/8" electric impact
don't even try to remove the hex bolt without a proper metric size key, you'll stripe it, i seem it before.
EF9 Sedan
Apr 9, 2015 10:33 PM
